Discover what hardware is used around the world to monitor energy usage. Learn how smart energy readers — like the Homey Energy Dongle — can help you identify large consumers and optimize your household's energy use.
- Track real-time energy consumption
 - Monitor electricity, gas, and water usage
 - Discover smart energy meters used across the world
 - Learn about alternative energy monitoring solutions
 - Enable automation through smart home platforms — like Homey
What are Smart Energy Meters?
Types of Smart Energy Meters
P1 Readers
- DSMR 4.x and earlier: Basic functionality with limited data updates. Provides 5V at 100 mA, insufficient to power P1-connected readers.
 - DSMR 5.x: Real-time updates with renewable energy systems support. Provides 5V at 250 mA, enough to power P1 readers including the Homey Energy Dongle.
 - DSMR 6.x: Real-time updates with smart grid integration and advanced encryption support. Provides 5V at 250 mA, enough to power P1 readers including the Homey Energy Dongle.
Countries using P1 Readers:
- 🇳🇱 The Netherlands
 - 🇧🇪 Belgium
 - 🇱🇺 Luxembourg
 - 🇩🇰 Denmark
 - 🇭🇺 Hungary
 - 🇸🇪 Sweden
 - 🇫🇮 Finland
 - 🇦🇹 Austria
 - 🇱🇹 Lithuania
 - 🇨🇭 Switzerland
HAN Readers
Countries using HAN Readers:
- 🇳🇴 Norway
 - 🇸🇪 Sweden
 - 🇩🇰 Denmark
 - 🇫🇮 Finland
Optical (Pulse) Readers
- 🇺🇸 United States
 - 🇨🇦 Canada
 - 🇬🇧 United Kingdom
 - 🇦🇺 Australia
 - 🇯🇵 Japan
 - 🇪🇺 Most European Countries
Clamp Readers
