Matter Compatible Devices You Can Use Today
When you first hear about Matter, it can sound like a promise for some distant future. A world where every smart home device works together, setup is quick, and compatibility is no longer something you need to check online before buying a light bulb. But the truth is that the future is already here. There are plenty of Matter-compatible devices available today, and you can use them with Homey Pro right now.
Whether you want to begin small or plan a full upgrade, this guide walks you through the types of Matter devices you can add today, how they fit into your home, and how Homey brings everything together. Think of this as a friendly tour of what is already possible, not a wishlist for someday.
Why Matter Devices Feel Different
Matter does not magically create new types of devices, but it does change how they behave. The biggest difference is the feeling of simplicity. Pairing becomes easier, reactions feel faster because everything communicates locally, and sharing devices between apps is no longer complicated.
If a device carries the Matter logo, it is designed to work with any major smart home ecosystem that supports the standard, including Homey. That gives you the freedom to build your home with the brands you prefer, rather than the ones that happen to be compatible.
Homey Pro acts as the unifying layer that helps your Matter devices interact with your existing Zigbee sensors, Z-Wave switches, and Wi-Fi appliances. It also acts as a Thread Border Router in your smart home, allowing you to pair Thread devices directly and without other requirements.
Smart Plugs That Do More Than Switch Power
Smart plugs are one of the easiest ways to start with Matter because they instantly turn almost any appliance into something smarter. They let you automate a lamp, track energy usage, or schedule electronics to turn off when you leave home.
Homey Best Buy Guide: Smart Plugs Featured
Eve’s Energy Smart Plug is a great example. It supports Matter-over-Thread, and when paired with Homey Pro or Homey Pro mini, you can combine it with other devices to create meaningful automations. A hallway lamp can switch on when your Apollo Presence Sensor detects movement or turn off automatically when everyone leaves the house. It is a small upgrade that quickly becomes part of your daily routines.
Homey Pro and Homey Pro mini support a range of Matter smart plugs, whether they use Wi-Fi or Thread as their underlying communication protocol. Shelly, Meross, Tapo, Leviton, Nous, WiZ are just some of the brands that produce smart plugs with Matter support.
Light Bulbs and LED Strips That Respond Instantly
Lighting is one of the most satisfying areas to automate. Matter improves this even further by offering fast performance, simple pairing, and strong multi-platform support. Many Matter lights use Thread, which gives you even faster responsiveness and excellent reliability.
smart light comparison lifx bulbs
The Nanoleaf Essentials Light Bulb is one of the most popular Thread-based Matter bulbs today. Once connected to Homey, it blends effortlessly with your other devices. You can use it for a cozy evening scene, automatically brighten your workspace in the morning, or add it to a whole-home lighting routine based on presence.
Matter also works with many multi-color light strips, making it easy to add mood lighting under cabinets, behind your TV, or along hallway edges. Govee, LiFX, Nanoleaf, and WiZ produce a range of bulbs and LED strips that work over Matter.
Switches and Buttons That Enhance Everyday Control
Matter support is steadily growing for smart wall switches. Brands like Leviton, Aqara, Eve, TP-Link, and Nanoleaf already offer Matter-ready wall switches that bring modern automation to traditional lighting. These switches give you familiar physical control while adding the benefits of local, reliable smart home integration.
Although wireless buttons are still an emerging category in Matter, many manufacturers are releasing new models that pair cleanly with Homey and give you a straightforward way to control your lighting and appliances without reaching for your phone. For example, the Arre Smart Button is a tiny, battery-powered button that works over Thread and executes single-, double-, or triple-press actions.
Sensors That Help Your Home Respond to You
Sensors are gradually becoming a solid part of the Matter ecosystem. Major brands like Aqara, Eve, and Tado now offer Matter-capable motion, temperature, and contact sensors that help your home react automatically to everyday activity.
For instance, a Matter motion sensor in your hallway can trigger a Zigbee light bulb you already own, thanks to Homey’s multi-protocol support. A temperature sensor can adjust heating routines, lowering your HeatIt Z-Wave thermostat when a room naturally warms up. Devices like the Thread Sensereo MS-1 smoke sensor can protect your home while becoming part of your wider Homey smart home.
Why Homey Makes Mixed Setups Feel Natural
One of the best things about adding Matter devices to Homey is the freedom it gives you. You do not need to commit to Matter for every category. You can still rely on your Zigbee door sensors, Z-Wave switches, Wi-Fi cameras, and Bluetooth trackers. Everything becomes part of the same system.
This approach lets you pick the best technology for each task. You can use a Matter bulb in the living room for fast control, a Zigbee sensor by the front door for reliability, and a Z-Wave switch in the hallway for long-range performance. Homey blends them into a single smart home that feels harmonious and easy to use.
Matter is no longer a future concept. It is here, it is growing, and it already fits beautifully into real homes. Whether you begin with a smart plug, a single Thread-based bulb, or a collection of switches and sensors, Homey makes the process smooth and flexible.
If you want to take the first step, choose one Matter device and connect it to Homey. Watch how easily it fits into your routines, and let your smart home grow naturally from there.
Frequently Asked Questions
Do all Matter devices support Thread?
No, some use Wi-Fi or Ethernet instead.
Can Matter lights work with my old Zigbee sensors?
Yes, Homey lets different technologies work together.
Is Matter faster than other protocols?
Not necessarily. However, Matter runs entirely locally over your home network, so commands are sent directly to the device without going to the cloud and back, improving latency.
Can I share a Matter device with Apple Home or Google Home?
Yes, multi-admin support makes this simple.
Do I need a new Matter hub?
No, Homey Pro already includes the required technology.
Are sensors widely available in Matter?
The selection is growing, and more options are on the way.
Can Matter plugs track energy usage?
Many can, including models like the Eve Energy.
Do Matter switches work offline?
Yes, Matter uses local communication.
Can I automate Matter devices with my existing routines?
Yes, Homey Flow works with any supported device.
Is it worth starting with just one Matter device?
Absolutely, it is the easiest way to explore the benefits.
