In these 'Behind the Magic' series we will give in-depth information about Homey and the technology behind it. Not only because we like geeky people and hopefully provide them some new insights, but also because we're proud of what we are building at Athom! This is the first post in the 'Behind the Magic' series and will give a general overview of Homey. After reading we hope you have some idea about how Homey works, and everything that went into making our product do what we hoped for!
Hardware
In order to produce a high quality product we believe it is essential that both the hardware and software are tailor-made to best serve its intended purpose. Think for example about gaming consoles, which can produce stunning graphics with a graphics card that is already years old. When we started with Homey there was of course no hardware we could get off the shelf, so we had to design our own. Considering our high quality requirements, eight (!) wireless protocols and an unusual design, it was definitely a challenge to fit all of that in a 12 cm sphere.
- MicroSOM (CPU, RAM, Wi-Fi & BT)
- 4 GB eMMC Flash
- Power Supply
- RGB LED (24x)
- Microphones (2x)
- Audio Chip
- 433 MHz
- 868 MHz
- Z-Wave
- ZigBee
- NFC (IC & antenna connector)
- Infrared LED (6x)
- Infrared receiver
We've often heard from respected partners that it's a miracle that we were able to get all these technologies work together without any problems. Our hardware designers really did an outstanding job here!
MicroSOM
The MicroSOM is the heart of Homey, and runs our own flavor of Linux. It communicates to all Homey's different chips over various interfaces: USB, I2C, UART and GPIO. It's IMX6 processor is clocked at a maximum speed of 1.0 GHz and has 512 MB RAM available, which allows for many apps to run on Homey.
Microcontroller
The MicroSOM's smaller brother, the Microcontroller, is placed between the 433 MHz and 868 MHz antennas. The Microcontroller takes care of those two frequencies (which in turn both have their own chip, the Texas Instruments CC1101). In addition the Microcontroller can control the LED ring while Homey is booting and manages the data stream generated by the accelerometer. A way to reset Homey was necessary, but a button wouldn't look good. This is where the accelerometer comes in handy. With the accelerometer Homey determines if it's turned upside down and can go into DFU (Device Firmware Upgrade) mode during the first 5 seconds of booting, or start Wi-Fi Recovery afterwards.
Audio
There are 2 state-of-the-art microphones placed inside Homey that record a high-quality stereo signal. The audio chip runs it's own DSP (Digital Signal Processing) software, which does noise reduction, volume optimisations and various filtering to ensure an optimised signal for our software processing. The audio chip can also play music over the internal speaker or to the jack-output, if connected. Homey also detects whether or not an audio jack has been plugged in. It can also keep track of volume states and sound muting. So, perhaps in the future if music should be playing but Homey's microphones are not hearing it, Homey can automatically attempt to turn on or unmute your speakers.
Software
Ambitious hardware simply deserves brilliant software. We have designed our own flavor of Linux based on Debian. There are multiple hand-crafted kernel modules such as the LED Ring driver and the Infrared driver. There is a system partition on Homey, where the system files reside. Most of the space, however, is reserved for user data on a separate partition. When you reset a Homey, this partition can be wiped and Homey starts like it's brand new.
Wi-Fi Recovery
Homey Core
When everything seems to be fine, the core of Homey is started by Linux. This is a Node.js application, which means that it's written mostly JavaScript. Because we are using this high-level language we can increase our development speed. Not only does Node.js offer the advantage of a relatively easy language, there are also many modules available made by the open source community that Homey utilises. We also give back to that open source community! For example our node-nfc, node-pcm2wav, node-linux-device and imx6-usermode-ocotp libraries are all open source. Homey Core creates a webserver, which is essentially an API for all of its features. It also serves the front-end HTML, CSS and JavaScript files for your browser to render. If you're connecting to your homey remotely these files are served from our CDN (Content Delivery Network), but more about that in a future post. Most API calls require authorization, so only you and the people you have granted access can control your Homey. We are also aiming to make access control more advanced in the future, comparable to sharing a folder on e.g. Dropbox. Homey Core talks to the Microcontroller, the LED Ring, the Audio Chip, the Z-Wave and ZigBee chips, the NFC chip and the Infrared LEDs and Infrared receiver. Mostly using native bindings, so code is executed in their own threads to keep things fast.
Apps
Devices
On a software architecture level the aim with Homey is to create a database of devices that 'can do things'. Those 'things' are called capabilities. Capabilities are what glues devices together in the Devices overview, but also in the Flow Editor, Insights and Speech. For example, a Philips Hue light bulb can do certain things. It can turn on or off, change color and change brightness. These are all seperate 'capabilities' of a device class 'light' in Homey. A paired Philips Hue device is registered with the capabilities `onoff`, `dim`, `light_hue`, `light_saturation` and `light_temperature`. Or a subset of these capabilities, when the light can only dim, for example. When you say "Turn all lights in the Living Room to red", Homey finds all devices you have in the Living Room that can turn to red. The Hue is matched from this database of devices, and a signal is sent to the app to turn that device to red, which in turn sends the signal to the light itself using the appropriate wireless technology. The Flow Editor also shows only the cards that are applicable for this device when you drag it around. The mobile card only shows the color wheel if your device can change color, etc. We designed the devices model like this so that regardless of the brand or a device's functionalities so it fits neatly in Homey. Even if your light has a native 'Disco Mode', you can simply add a Flow action in your App which smoothly integrates next to the default Flow actions such as 'Turn on' and 'Dim'. In general our aim is to connect different devices in the way that creates the smoothest user experience!
Cloud
We've designed Homey to be mostly independent of Cloud services, because there's nothing more frustrating than not being able to turn your lights on because some 3rd party doesn't feel like it that day. So Homey itself is fully accessible locally, and in the improbable event that Athom goes bankrupt and is forced to shutdown the servers, most Homey functionality will still work. That doesn't mean that our Cloud isn't a work of art in itself though. We maintain various services running to extend Homey. Most of them can also be found on our Athom Status, as well as their health.
My Athom
This is the portal to your Homey(s). It is also the server that your Homey is always connected with, so you can reach it from anywhere in the world. When you're visiting my.athom.com on your local network, it automatically detects this. That way, when you click on your Homey, the browser is redirected to the Homey's LAN address for the quickest interaction. When your Homey can not be reached locally, a proxy URL will be used. This looks like https://your_homey_id.homey.athom.com and is unique for that specific Homey. All traffic that goes to that URL is proxied through My Athom, and from there to your Homey over the persistent connection it has with My Athom. When using this proxy, you can imagine we have to handle a lot of traffic. Luckily we've built the system so that all content such as images, fonts, html etc. is downloaded from our CDN, a Content Delivery Network that has servers across the world. So only the Homey-specific traffic, or 'API calls', are proxied. Not bad, right? This might seem cumbersome, but the alternative would have been to let the user open ports in his or her router, disable firewalls etc. That would be a technical hassle we didn't want our users to have to go through, as it goes against our 'even my mom can use it'-philosophy. (Sorry, mom.)
App Store
The App Store is where you go to get new Apps for your Homey. When logged in, you can select which Homey you want to install the app to.
Developers can submit their Apps here as well, which are then reviewed by someone at Athom to assure the quality is up to par. This review process will get better over time, because we also have to learn what non-Athom developers come up with!
API
Setup
Speech to Text
This is the service that converts audio into a piece of text of what you said. When Homey has heard 'OK Homey', a connection to this server is opened, and the microphone's recordings are streamed to this server, until a certain amount of silence has been heard. This server then forwards the audio to 3rd party services, and when they come back, we compare them to pick the best result. A few factors are weighted here such as speed, accuracy and 'dynamic-ness'. Some servers are very good at dynamic words such as artists or movie names, but they are generally slower. So when we detect words that hint on dynamic words, such as 'music', 'movie', 'play' etc, the Speech to Text service at least waits for the 3rd party service that's best at detecting those to finish. This way we can ensure the best results for each scenario.
Firmware
Notifications
Webhooks
Callback
Other services
