🖤 Save 400 kr on Homey Pro and 12.5% on everything else with code BLACKFRIDAY24
Homey as Energy Management System
  • Energy measurements
  • Heating and cooling
  • Major energy consumers in the home
  • EVs and EV chargers
  • Energy pricing, including dynamic tariffs
  • Solar at home
  • Home energy storage, like home batteries
Energy measurements in Homey
Smart heating in Homey
All sorts of heating systems are ultimately controlled by thermostats. There's smart thermostats available for almost every heating setup. Homey is compatible with a wide range of thermostats for multiple heating configurations:
  1. Multi-zone heating with different thermostats. Popular in Scandinavian countries like Norway and Sweden. Homey works with products from Heatit for this option (via Homey Bridge), among other brands.
  2. Heating with a main thermostat (either single or multi-zone). Popular in Western Europe. Homey works with many brands, including Honeywell Evohome, Tado and Netatmo for multiroom, plus Toon, Nest, ecobee and more for single room.
  3. Multi-zone heating with just radiator thermostats. Popular in Germany / DACH and Central Europe. Smart radiator thermostats from Eurotronic, Aqara, Danfoss, Fibaro and more can be paired to Homey Bridge or Homey Pro.
  4. Heating (and cooling) via air conditioning. While you might think of an AC for cooling, the fact that it's based on a heat pump makes it a pretty decent and efficient heater as well. Homey works with connected ACs from Daikin. Homey Pro adds support for Panasonic and Mitsubishi, and both Homey and Homey Pro can connect to Infrared AC controllers from Switchbot and Tado.
  5. Electric space heaters. Brands like Mill and Adax have connected space heaters that work with Homey Pro. Next to that, most simple space heaters can be switched on and off with a simple smart plug.
Major energy consumers in Homey
Next to your heating, major energy consumers in your home might include washer/dryers, dishwashers, electric or induction stoves, electric ovens, freezers and possibly a sauna or pool if you have those. Some of these can be bought smart and can be connected to Homey. Others can be made smart with a smart relay.
Homey is compatible with quite some brands of connected appliances / white goods, including Bosch, Siemens and Miele. Next to that, you can monitor and control major consumers using smart plugs and built-in modules with energy measurement functionality. These can be from
Installing solar panels on your home help you generate your own renewable energy, save money on your electricity bills, and reduce your carbon footprint. To effectively manage your solar energy, it's important to monitor your energy consumption and production to ensure you're using your solar energy efficiently, ideally on the times you're also generating it.
Solar panels themselves are pretty dumb. It's the inverter that is bridging your panels to your grid where it becomes interesting. Homey can integrate with solar panels in two different ways:
  1. A connected inverter. Homey Pro works with many different inverters from popular brands, including EnPhase, Growatt, SolarEdge, SMA, Tigo, GoodWe and Huawei.
  2. A connected smart meter add-on with separate solar value. Usually this is called a '3-phase meter'. Both Homey and Homey Pro integrate with the Tibber Pulse for this.
