Heat Pumps and Hybrid Heating with Homey: Smarter Control, Better Efficiency
As more homes switch from traditional boilers to heat pumps or hybrid systems, heating becomes not just a question of “on or off”, but of strategy. These systems are at their best when they run in a thoughtful, coordinated way.
A heat pump can deliver impressive efficiency, but it is sensitive to how and when it operates. A hybrid system offers flexibility between gas and electricity, but that flexibility only pays off if it is used intelligently. That’s where a HEMS led by Homey can make a significant difference.
Heating as a System, Not a Thermostat
In older setups, the thermostat was effectively the entire “brain” of the heating system. It measured a single room and controlled the boiler accordingly. In a modern home with multiple zones, underfloor heating, smart valves and on top of that solar and dynamic pricing, this single point of view is no longer enough.
Homey’s strength is that it sees more than the thermostat. It can know which rooms are occupied, what the outdoor conditions are, how much power your home is drawing, what your panels are producing and what energy costs at that moment. It can then combine these factors into a more nuanced heating strategy.
For example, if the living room and kitchen are active, but the rest of the house is empty, Homey can make sure those zones get priority. If the home office is in use, it might get comfort while bedrooms stay cooler. When nobody is home, the entire system can shift to a more conservative mode—ready to ramp up when someone returns.
Heat Pumps: Playing to Their Strengths
Heat pumps prefer to run steadily at relatively low output, rather than ramping up and down aggressively. Their efficiency is higher when temperature differences between source and target are modest. This means that subtle, continuous control often beats extreme swings.
By integrating your heat pump controls, thermostats and radiator valves with Homey, you can shape behaviour that fits this profile. Instead of letting the building cool down dramatically and then demanding a rapid heat-up, you can maintain a comfortable baseline and make smaller adjustments based on presence and tariffs.
During periods when electricity is cheap or solar output is strong, Homey can allow the heat pump to work a bit more, raising indoor temperatures within comfortable limits and effectively “storing” some energy in the building structure. During peak price periods, it can ease off slightly, relying on that stored warmth.
The goal is not to make your home hot and cold by turns, but to use gentle shifts and smart timing to get more comfort from less energy.
Hybrid Systems: Choosing the Right Source at the Right Time
Hybrid heating systems combine, for example, a gas boiler and a heat pump. They are designed to choose between or combine sources based on temperature and other conditions. That choice, however, is often made using fixed rules that may not fully reflect your energy priorities.
When a hybrid system is integrated with Homey and your HEMS, this source selection can become more informed. If electricity is cheaply available or you have abundant solar production, it may make sense to lean more heavily on the heat pump. If electricity is particularly expensive or the heat pump is operating in unfavorable conditions, the boiler might play a larger role.
Homey can feed tariff and solar data into your heating logic, turning hybrid decisions into more than just outdoor temperature comparisons. You can even adapt your strategy as contracts or panel yields change over time.
Comfort, Noise and Practical Realities
While efficiency is important, comfort and practicality cannot be ignored. Heat pumps can be noisier than traditional boilers, especially in outdoor units. Certain rooms may be more sensitive to temperature swings than others. People may have strong preferences about bedroom temperatures or start times.
Homey allows you to encode these human realities into your heating strategy. Quiet hours can be respected by limiting certain types of operation at night. Bedrooms can maintain slightly different setpoints from living spaces. Special schedules for weekends, work-from-home days or holidays can be overlaid on top of the general HEMS logic.
Because Flows are adjustable, you can refine this behavior as you live with it. A pattern that looked good on paper but feels a little cool on winter mornings can be softened. A setpoint that proves unnecessarily high can be nudged downward.
Heat Pumps as Citizens of Your HEMS
A heat pump or hybrid system is a major investment in your home’s future. Therefore, you need to treat it as a central player in your HEMS, not as an isolated upgrade.
By connecting heating to Homey, you give it the context it needs to shine: presence, solar, tariffs, zone usage and comfort preferences. In return, your heating system rewards you with better efficiency, more stable comfort and a sense that your home is truly managing its energy in a modern way.
FAQs
Why is a traditional thermostat not enough for a heat pump?
Traditional thermostats usually measure temperature in a single location and turn the heating on or off based on that one number. A heat pump works best with a broader view—considering multiple zones, outdoor weather, energy prices, and solar availability—which requires a central HEMS to coordinate.
How does automation improve heat pump efficiency?
Heat pumps are most efficient when they run steadily at a low output ("low and slow") rather than constantly turning on and off. Automation helps maintain this steady state by making small, proactive adjustments based on trends rather than waiting for the room to get cold and then blasting heat.
How does a hybrid system decide between gas and electricity?
Without smart control, hybrid systems often switch based on simple outdoor temperature rules. When integrated into a HEMS, the system can make smarter financial decisions, choosing the gas boiler when electricity prices are high, and switching to the electric heat pump when prices drop or solar power is available.
Can I use my home’s structure to store energy?
Yes. By slightly increasing the temperature during sunny or cheap hours, you can "charge" the thermal mass of your floors and walls. This stored heat is then slowly released back into the room later in the day, reducing the need to run the heat pump during expensive peak hours.
Does saving energy mean sacrificing comfort or silence?
No. A smart system allows you to prioritize specific needs, such as "Quiet Modes" at night to reduce outdoor unit noise. It also enables zoning, where you only heat the rooms you are actually using (like a home office) while keeping empty rooms (like bedrooms) cooler during the day.
Hybrid Heat Pump
A heating system that combines an electric heat pump with a traditional gas boiler. The system switches between the two fuel sources based on efficiency, outdoor temperature, and (with a HEMS) energy costs.
Heat Pump Modulation
The ability of a heat pump to adjust its output power up or down to match the exact heating demand of the home. This avoids the inefficient "stop-start" cycles common in older heating systems.
Smart Radiator Valve (TRV)
A motorized valve attached to a radiator that allows a HEMS to control the temperature of a single room wirelessly. These are essential for creating a zoned heating system in homes without underfloor heating.
Zoned Heating
The practice of concentrating warmth in specific rooms where people are actually located, rather than heating the entire house to the same temperature. This creates higher comfort in occupied areas while significantly reducing energy waste in empty ones.
Thermal Mass
The ability of a building's materials—such as concrete floors or brick walls—to absorb and store heat. This acts like a "thermal battery," stabilizing indoor temperatures and allowing for energy storage strategies like pre-heating.
