Introducing dbrand skins for Homey Pro mini
You can now personalize your Homey Pro mini with precision-cut skins from dbrand. Yes, the same dbrand trusted by MKBHD, Linus Tech Tips, and probably any other tech YouTuber you’ve just watched. They’ve wrapped phones, consoles, laptops... even a Porsche. Now it’s Homey’s turn.
Unnecessarily accurate
If you know dbrand, you already get it. If you don’t, they make ultra-precise vinyl skins that fit perfectly, go on clean, and peel off without a trace. It’s part pixel-perfect design, part robot-fueled sarcasm.
Pick your finish
Homey Pro mini skins start at $19.95 and are available in finishes such as Triple Black, White Marble, Obsidian, Glow Circuit, and more. Some are subtle. Some are loud. All fit like a glove, precision-cut to the molecule using materials that make your router weep.
Explore dbrand skins for Homey Pro mini
Overkill? Obviously. But so is buying a smart home hub to avoid getting off the couch. Stick one on. Or don’t. But now you can. Check out the full collection at dbrand.com →
