                Raspberry Pi automation or Homey? Compare Domoticz, Home Assistant and Homey
Pricing
| Homey | Raspberry Pi- based Domoticz, Home Assistant | |
| Base Price | € 299 | € 65 1 |
| Wireless technologies | ||
| Z-Wave Plus | ✔️ included | + € 50 2 |
| Zigbee | ✔️ included | + € 50 3 |
| Wi-Fi | ✔️ included | ✔️ included |
| Bluetooth Low Energy | ✔️ included | ✔️ included |
| 433 MHz - Trust / DIO | ✔️ included | + € 100 4 |
| 433MHz - Somfy | ✔️ included | + € 100 4 |
| Infrared | ✔️ included | + € 30 5 |
| KNX-IP | ✔️ included | + advanced configuration |
| Out of the box cloud services | ✔️ included | + $5 /month (HA) ❌ (Domoticz) |
 4 RFXcom setup
 5 Broadlink RM 3 Mini
Capabilities
Home automation in Domoticz
Home automation in Homey
Flexibility and maintenance
- Remote access to your home to control, monitor or even adjust a Flow
- Update or install new components in your system
- More and more devices are connected via cloud APIs like OAuth. For instance smart thermostats
- Voice assistants might prove to be a good way to control some aspects of your smart home
The choice
