Discover the new Homey Portal
Zigbee vs Thread: Understanding Low Power Smart Home Networks
As smart home technology evolves, two names keep coming up often: Zigbee and Thread. Both are low power wireless standards designed for smart devices that make a home feel truly connected. They both focus on fast response times, long battery life and mesh networking. And even though Thread is newer and part of the Matter standard, Zigbee continues to be an incredibly strong and trusted foundation for sensors and switches in real homes.
If you are trying to understand where each technology fits, or whether one will replace the other, this guide will help you make sense of the differences. Best of all, when you use Homey Pro or Homey Pro mini you do not have to choose between Zigbee and Thread at all. Homey supports both, so you can build a home that feels modern and stable without worrying about the underlying protocols.
What Zigbee and Thread Have in Common?
Zigbee and Thread exist for the same reason. They were created so that low-power, low-bandwidth devices could communicate efficiently without using much power. Wi-Fi is great for streaming and cameras, but it drains batteries quickly. Bluetooth is handy for pairing but not ideal for whole home coverage. 433 MHz and Infrared are one-way protocols, not suitable in many usage scenarios.
Zigbee and Thread fill the space in between by focusing on small, lightweight messages. When a motion sensor detects movement, or a door sensor opens, these protocols send that information quickly and reliably.
Both protocols also use mesh networking. A mesh network allows devices to pass messages to each other. When you add a new powered device such as a smart plug or smart bulb, it becomes a small repeater. This helps your network stretch further into your home. The more routers you add, the stronger your network becomes. This is part of what makes Zigbee and Thread so dependable in real daily use.
Where Zigbee and Thread Differ?
Even though Zigbee and Thread share the same purpose, they have different backgrounds. Zigbee is a mature standard with years of development. It has thousands of compatible devices and covers everything from sensors to lights to wall switches.
Thread is newer and was built with the future in mind. It focuses heavily on stability, low power usage and a deeper integration with modern smart homes. Thread is also part of the Matter standard, which makes it easier to connect devices across platforms.
Zigbee devices talk directly to a Zigbee coordinator, such as Homey Pro. Thread devices form a similar mesh but need a Thread Border Router to connect them to your smart home platform. Homey Pro includes its own Thread Border Router, which means Thread devices can join Homey without extra hardware.
Thread networks require a Thread Border Router like Homey Pro
One of the biggest differences today is availability. Zigbee still offers far more device types from various brands and vendors. Many of the most popular devices, especially from brands like Frient or Sonoff, are Zigbee. Thread is growing very quickly, especially for lights and smart plugs such as the Nanoleaf Essentials line-up, but it is not as widely used yet.
How Zigbee and Thread Perform in Real Homes
Zigbee and Thread provide remarkably similar performance in typical household settings because they share the same underlying radio frequency and mesh networking principles. In a real-world environment, both protocols offer snappy, with near-instantaneous response times for tasks like turning on a light or receiving a motion alert.
Because they both operate as a mesh, the signal becomes stronger and more reliable as you add more mains-powered devices, like smart plugs or light switches, which act as repeaters to bridge gaps between distant rooms. A well-configured mesh ensures that commands reach their destination without noticeable lag regardless of the specific protocol used.
Modern smart home hubs like Homey Pro handle these signals with extreme efficiency, making the interaction feel natural and immediate for the user. In practice, the "snappiness" of a smart home depends more on the density of the mesh and the quality of the routing devices than on whether the network is running Zigbee or Thread.
Choosing Between Zigbee and Thread
The good news is that you rarely need to choose between one or the other. Zigbee continues to shine for sensors and small devices, while Thread is emerging strongly for lighting and Matter certified products. If you prefer the stability of established devices, Zigbee is an excellent choice. If you want to explore the world of Matter and Thread, you can start with one or two devices like the Eve Energy smart plug using Matter.
Homey Pro removes the pressure of making the perfect choice. Homey supports both Zigbee and Thread, along with Matter, Z-Wave, Wi-Fi, Bluetooth, 433 MHz and Infrared. Whether you buy a Zigbee sensor or a Thread light, Homey understands it and helps you combine it with every other device in your home.
Why Homey Makes the Combination Feel Natural
Homey does not force you into one protocol. You can use a Zigbee motion sensor to trigger a Thread based light bulb. You can let a Zigbee contact sensor interact with a Matter plug like Eve Energy. Or, you can build scenes and routines that mix technologies seamlessly. Homey brings all protocols together so your smart home feels like one unified system.
This also means you can let your smart home grow naturally. If your next favorite device happens to use Zigbee, great. If it uses Thread or Matter, also great. Homey keeps everything working smoothly without asking you to choose a single direction for the future.
Zigbee and Thread are not competitors. They are two powerful technologies built for the same purpose. Zigbee offers proven reliability, a huge range of devices and excellent performance for everyday sensors. Thread brings a modern approach with strong local control and deep integration with Matter.
With Homey Pro supporting both, you have the freedom to use whichever technology fits your home, room by room and routine by routine. If you want a smart home that feels fast, flexible and ready for the future, choose the devices you love and let Homey connect them all effortlessly.
Is Thread replacing Zigbee?
Not in the near future. Zigbee remains widely used and highly reliable. Both technologies will coexist for many years.
Do Zigbee and Thread devices work together?
Not directly, but they work together inside Homey Pro through Flows and shared routines.
Is Thread better than Zigbee?
Both have strengths. Thread integrates well with Matter while Zigbee has a larger ecosystem today.
Does Homey Pro support Thread?
Yes. Homey Pro includes a built in Thread Border Router.
Which is better for sensors?
Zigbee currently offers more sensor choices and excellent battery life.
Which is better for lighting?
Thread based lights often respond very quickly and integrate well with Matter.
Can I use both Zigbee and Thread in one home?
Yes. Homey Pro is designed for homes that mix technologies.
Does Zigbee interfere with Wi Fi?
It can overlap in frequency, but a strong mesh and good device placement prevent issues.
Do Thread devices need the internet?
No. Thread operates locally, similar to Zigbee.
What should I buy first if I want to try Thread?
A simple Thread or Matter device like the XXX or a supported smart plug is a great starting point.
