🖤 Save C$69 on Homey Pro and 12.5% on everything else with code BLACKFRIDAY24
Best Buy Guide
Smart Light Bulbs
Best Buy Guide
Smart Light Bulbs
Discover the Best Smart Bulbs for Your Smart Home.
Choosing Smart Lights Bulbs
  • Connectivity: Prioritize bulbs with reliable wireless connectivity protocols such as Matter (Thread) or Zigbee to strengthen your home mesh network.
  • Brightness and color control: Assess whether dimmable or color-controllable bulbs are necessary for your needs. Sometimes a simple on/off light bulb will do just fine (e.g., hallway).
  • Quality: Consider the integrity of the brand producing the smart bulbs to ensure a certain level of quality. Opt for reputable brands highlighted in our Best Buy Guide.
  • Energy efficiency:  Smart light bulbs vary in their energy efficiency, which can affect both your electricity bill and environmental impact. Look for bulbs with high efficiency ratings and avoid exceeding your necessary wattage.
  • Price: With a standard home potentially requiring between 10 to 50 light bulbs, costs can add up quickly. Consider the prices highlighted in this article to stay within your budget.
BrandModelsProtocolPrice
IKEATradfri Smart LightingZigbeeFrom €7.99
Nanoleaf IconNanoleafEssentials Light BulbsThreadFrom €19.99
Philips HueWhite and Color AmbianceZigbeeFrom €29.99
Govee Smart LED Bulbs
Available at €12.99
Shop now
  • Affordable
  • Vibrant colors
  • Suitable as ambient lights
  • Low maximum brightness
Homey Pro
Homey
Ikea Tradfri Smart Lighting
Available at €7.99
Shop now
  • Affordable
  • Great whites
  • Wide range of light bulbs
  • Mediocre color spectrum
Homey Pro
Homey Bridge
Ikea's Tradfri product line offers a diverse selection of ambient lights, ceiling lights, lamps, and light bulbs. They provide a cost-effective solution for transforming your home lighting into a smart system, particularly when purchased in bulk.
Within Ikea's smart light bulb range, you'll find various options, including basic dimmable bulbs, RGB bulbs, spotlights, globe-shaped bulbs, and filament bulbs reminiscent of traditional lighting.
The Tradfri lights use Zigbee to communicate with your Homey Bridge or Homey Pro directly, skipping the Tradfri gateway completely. The IKEA Tradfri app enables simple On/Off toggles, temperature and brightness control as well the ability to adjust hue and saturation of RGB bulbs.
While the white and warm white illumination beaming at 1000 lumens of the Ikea Tradfri bulbs is great, they have a mediocre color rendering index, with colors feeling very pale.
Innr Smart Lighting
Available at €9.99
Shop now
Innr Smart Lighting
  • Very affordable
  • Long life span
  • Zigbee router
  • Not suited for large rooms
Homey Pro
Homey Bridge
LIFX Smart Lights
Available at €25.99
Shop now
LIFX Smart Lights
  • High-quality build
  • Excellent CRI
  • Night Vision Infrared model
  • Pricier than competition
Homey Pro
Homey
Available at €19.99
Shop now
  • Matter light bulbs
  • Thread router
Homey Pro
Available at €29.99
Shop now
  • Premium quality
  • Durable and reliable
  • Expensive
Homey Pro
Homey
Sengled Smart Bulbs
Available at €14.99
Shop now
Sengled Smart Bulbs
  • Great quality
  • Versatile portfolio
  • Built-in energy meter
Homey Pro
Homey Bridge
Most Sengled bulbs are equipped with a built-in energy meter, allowing the user to monitor the power draw of each light. Among their full stack of light bulb choices, lies an interesting gem of a device: a motion-activated light bulb, with a built-in PIR motion sensor! This model automatically turns on when it detects motion within its huge range of 12 meters.
Available at €14.40
Shop now
  • Affordable
Homey Pro
Homey
Wiz Connected Smart Bulbs
Available at €10.99
Shop now
  • Great build quality
  • Vibrant colors
Homey Pro
Yeelight Smart Bulbs
Available at €15.95
Shop now
  • Good build quality
  • Great colors
  • Music sync
  • Limited models variety
Homey Pro
Homey
About Matter Light Bulbs
Summary
