Discover the new Homey Portal
Homey Pro vs. Home Assistant
Homey Pro on the left and Home Assistant Green on the right
What You Should Consider
Different Approaches
Homey Pro and Home Assistant are popular choices for home automation with different underlying principles. In summary, Homey provides a user-friendly and seamless experience for controlling smart devices in the home — right from the start. It emphasizes simplicity and ease of use, allowing you to set up and control your smart home without extensive technical knowledge. Home Assistant, on the other hand, focuses on flexibility and customization. It’s open-source and gives you control over every aspect of your smart home setup. It supports many devices and integrations, making it a good choice if you want to fine-tune every detail.
Ease of Use
Device Control
Arguably, device control is the most frequently used feature of any smart home hub. It’s where you go to adjust anything — from the brightness of your lights to the position of your blinds.
The Homey app’s main dashboard provides a clear and concise overview of all connected devices. It displays their status at a glance, allowing you to quickly see which devices are on, off, or in a specific state. Each device type has a unique design optimized for its particular functions. This way, you can switch your lights on and off immediately, while the dimming functions and color picker are always just one tap away. Controls are intuitive, with sliders, buttons, and toggle switches that mimic real-world interactions.
Device Compatibility
When selecting a smart home hub, you want to ensure it is compatible with all your current and future devices. Both platforms do an excellent job here, each in its own unique way.
Apps can be installed on Homey Pro, just like you do on a smartphone
Homey Pro supports multiple protocols out of the box, including Matter, Thread, Zigbee, Z-Wave, Wi-Fi, and Bluetooth. It also natively supports many popular platforms, including Philips Hue, Sonos, Nest, and others. Integrations with devices and services are all Homey Apps, like on your smartphone. The Homey App Store is loaded with apps from Homey itself, partner brands, or developers from the Homey community. As a result, Homey adds new options at an inimitable pace. Apps are approved and then published in the Homey App Store. This way, everyone can enjoy it, even if you can’t program yourself.
Automation
Automation with Homey Pro
In addition, Advanced Flow can take your home automation to the next level. Advanced Flow offers a user-friendly visual interface for creating automation through an intuitive drag-and-drop system. It lets you easily comprehend the flow of your automation. As you create your Flows, you receive real-time feedback and can immediately see if it works as expected. This instant feedback loop helps you troubleshoot and refine your automation quickly.
When using Home Assistant, you automate by setting up Triggers, Conditions, and Actions. You are allowed to select Multiple Triggers to activate the automation. If Conditions are added, they must be met, and the specified Actions will then be carried out. These elements involve some programming logic, which might be challenging if you have less experience in this area. Scenes are a more straightforward automation that enables you to trigger a series of actions. You can also add automation and scenes as Widgets for quick access.
Additionally, Home Assistant lets you use blueprints. These pre-made automations require specific configurations, which vary depending on the blueprint. However, using one saves time as you don’t have to start from scratch. It also ensures your automation follows best practices, reducing the risk of errors. The community creates and shares blueprints, benefiting you from various solutions. In summary, using blueprints in your Home Assistant setup can greatly enhance your automation capabilities and bring new ideas to your smart home projects.
Scripting & Customization
For those interested in it, scripting offers ultimate power and freedom. Yes, power users, we’re talking to you.
You can create and run HomeyScripts from within an Advanced Flow
Stability
You have a smart home to make your life easier, not harder. Therefore, stability matters. It means you won’t have to deal with constant troubleshooting and maintenance. Let’s look at each platform’s approach.
With the Homey Pro Ethernet Adapter, you have reliable wired connectivity
Security & Privacy
Community & Support
What About Costs?
The full Homey Pro experience
Homey Pro is available as a one-time purchase
Should I Choose Homey Pro or Home Assistant?
Happy Automating!
