Best Buy Guide
Smart Light Bulbs
Best Buy Guide
Smart Light Bulbs
Find the best smart bulbs for your smart home
Choosing Smart Lights Bulbs
Connectivity
Prioritize bulbs with reliable wireless connectivity protocols such as Matter (Thread) or Zigbee to strengthen your home mesh network.
Brightness and color control
Assess whether dimmable or color-controllable bulbs are necessary for your needs. Sometimes a simple on/off light bulb will do just fine (e.g., hallway).
Quality
Consider the integrity of the brand producing the smart bulbs to ensure a certain level of quality. Opt for reputable brands highlighted in our Best Buy Guide.
Energy efficiency
Smart light bulbs vary in their energy efficiency, which can affect both your electricity bill and environmental impact. Look for bulbs with high efficiency ratings and avoid exceeding your necessary wattage.
Price
With a standard home potentially requiring between 10 to 50 light bulbs, costs can add up quickly. Consider the prices highlighted in this article to stay within your budget.
BrandModelsProtocolPrice
Aqara Brand LogoAqaraT2 LED BulbsThreadFrom €19.99
IKEAKAJPLATS Smart BulbsThreadFrom €6.99
Nanoleaf IconNanoleafEssentials Light BulbsThreadFrom €19.99
Nous IconNousMatter Light BulbsMatterFrom €9.99
Philips HueWhite and Color AmbianceZigbeeFrom €29.99
Aqara T2 LED Bulbs
Available at €19.99
Shop now
Aqara T2 LED Bulbs
  • Dual protocol
  • High brightness
  • Wide color range
  • Slightly larger than standard (E27)
Homey Pro
Homey Pro mini
Homey Cloud *
Homey Self-Hosted Server *
* Requires Homey Bridge
The Aqara LED Bulb T2 is a versatile smart lighting solution available in E26, E27, and GU10 fittings, offering both Tunable White (CCT) and RGB versions. It stands out with its dual-protocol support, allowing you to choose between the established Zigbee standard or the newer, future-proof Thread protocol (via Matter).
Whether you connect via Matter over Thread or Zigbee, the bulb integrates seamlessly with your Homey Pro, offering the same robust set of features across both protocols. In both modes, it acts as a reliable router to strengthen your mesh network without needing a proprietary hub. In Zigbee mode, users can connect the T2 directly to Homey Bridge or Homey Pro.
The bulb delivers high-quality illumination with a CRI of >90 and brightness up to 1100 lumens (E26/E27 versions) or 450 lumens (GU10), ensuring vibrant colors and crisp whites (2000K-9000K). It also features Power-Off Memory, letting you decide if the light should return to its last state or stay off after a power outage—a crucial feature for bedroom lamps. It’s worth noting that the E27 version of the bulb is slightly larger than standard (E27 is 60x108mm), so it is worth giving your fixture clearance a quick check.
Govee Smart LED Bulbs
Available at €12.99
Shop now
  • Affordable
  • Vibrant colors
  • Suitable as ambient lights
  • Low maximum brightness
Homey Pro
Homey Pro mini
Homey Cloud
IKEA KAJPLATS Smart Bulbs
Available at €6.99
Shop now
  • Very affordable
  • Matter over Thread
  • Wide range of light bulbs
Homey Pro
Homey Pro mini
The IKEA KAJPLATS range represents a massive shift in the smart lighting market, offering fully Matter over Thread certified bulbs at unbeatable IKEA prices. By adopting Thread, these bulbs connect directly to your Homey Pro without needing the IKEA Dirigera hub.
The lineup is surprisingly comprehensive from day one. It includes standard E27 and E14 globes, GU10 spotlights for recessed lighting, and stylish decorative filament bulbs (clear glass) that look great exposed in open fixtures. Depending on the model, you can choose between basic dimmable warm white, Tunable White (allowing you to shift from cozy warm to focus-friendly cool white), or full Color (RGB) versions to set the mood.
IKEA KAJPLATS features high brightness options, with some E27 models pushing out 1600 lumens, making them powerful enough to light up large rooms single-handedly. Furthermore, these bulbs support a dynamic color loop feature and adjustable transition times, allowing for smooth fading effects and automated mood lighting directly from Homey.
What makes this range truly disruptive is the price point. With basic bulbs starting around €5 and color versions around €10-€13, KAJPLATS is effectively the most affordable way to build a Matter-based smart home.
Innr Smart Lighting
Available at €9.99
Shop now
Innr Smart Lighting
  • Very affordable
  • Long life span
  • Zigbee router
  • Not suited for large rooms
Homey Pro
Homey Pro mini
Homey Cloud *
LIFX Smart Lights
Available at €25.99
Shop now
LIFX Smart Lights
  • High-quality build
  • Excellent CRI
  • Night Vision Infrared model
  • Pricier than competition
Homey Pro
Homey Pro mini
Homey Cloud
Available at €19.99
Shop now
  • Matter light bulbs
  • Thread router
Homey Pro
Homey Pro mini
Nous Matter Light Bulbs
Available at €9.99
Shop now
  • Very affordable
  • Matter bulbs
  • Variety of fittings
Homey Pro
Homey Pro mini
The Nous P-series smart bulbs (P3, P4, and P8) represent one of the most affordable entry points into the Matter ecosystem. Unlike many budget options that rely on proprietary clouds or gateways, these bulbs feature Matter over Wi-Fi, allowing them to connect directly to your Homey Pro.
The lineup covers the three most common fitting types to outfit your entire home: the P3 is a standard E27 bulb (810 lumens), the P4 is a smaller E14 candle bulb (380 lumens), and the P8 is a GU10 spotlight (420 lumens). All three models offer full RGB color mixing alongside Tunable Whites (2700K-6500K), letting you switch between functional cool daylight for working and cozy warm white for relaxing.
While they lack the ultra-high CRI or brightness of premium brands like Philips Hue or the Aqara T2, they offer incredible value for money. They are ideal for outfitting secondary rooms, hallways, or lamps where top-tier color rendering isn't critical. Because they use Wi-Fi (2.4GHz), they are "plug and play" devices—simply screw them in, scan the Matter QR code with Homey, and you are ready to go.
Available at €29.99
Shop now
  • Premium quality
  • Durable and reliable
  • Expensive
Homey Pro
Homey Pro mini
Homey Cloud
Sengled Smart Bulbs
Available at €14.99
Shop now
Sengled Smart Bulbs
  • Great quality
  • Versatile portfolio
  • Built-in energy meter
Homey Pro
Homey Pro mini
Homey Cloud *
Most Sengled bulbs are equipped with a built-in energy meter, allowing the user to monitor the power draw of each light. Among their full stack of light bulb choices, lies an interesting gem of a device: a motion-activated light bulb, with a built-in PIR motion sensor! This model automatically turns on when it detects motion within its huge range of 12 meters.
Available at €14.40
Shop now
  • Affordable
Homey Pro
Homey Pro mini
Homey Cloud
WiZ Connected Smart Bulbs
Available at €10.99
Shop now
  • Great build quality
  • Vibrant colors
Homey Pro
Homey Pro mini
Homey Cloud
Yeelight Smart Bulbs
Available at €15.95
Shop now
  • Good build quality
  • Great colors
  • Music sync
  • Limited models variety
Homey Pro
Homey Pro mini
Homey Cloud
About Matter Light Bulbs
Summary
