Control Zigbee devices via Amazon Alexa with Homey
Some Amazon Echo (and eero) devices have Zigbee built-in, so certain Zigbee devices can be paired directly to Alexa. If your Alexa device doesn’t have Zigbee, or if you want more advanced automation and broader device support, you can pair your Zigbee devices with Homey instead. Homey then exposes those devices to Alexa, so you can still use Alexa for voice control while Homey remains the “brain” for your automations.
So when does Homey come in?
Homey is most useful when you want:
  • One place to manage everything (Zigbee plus other brands/protocols)
  • More advanced automation than Alexa routines (conditions, logic, multi-step flows)
  • Better control consistency across devices that may show up as “basic” in Alexa
  • A setup where Homey remains the brain, and Alexa is the voice layer
This article explains the Homey approach step-by-step.
What you need
To control Zigbee devices via Amazon Alexa, you need:
Zigbee devices must always be paired with Homey first, before they are added to Amazon Alexa.
What “exposing devices” means
When Homey exposes a Zigbee device to Amazon Alexa, it means Homey shares that device with Alexa.
The device:
  • stays paired with Homey
  • becomes visible in the Alexa app
Amazon Alexa does not communicate with Zigbee devices directly. All commands go through Homey. A simple way to think about it is that Homey translates between Zigbee and Alexa.
How to expose Zigbee devices to Amazon Alexa with Homey
To control Zigbee lights, plugs, or sensors with Alexa, you need a smart home hub that supports Zigbee and can expose those devices to Amazon’s platform. Homey acts as that hub.
Zigbee devices stay paired with Homey, and Alexa accesses them through the Homey integration.
The process works like this:
  2. Connect Homey to Amazon Alexa
  3. Discover devices in the Alexa app
    Open the Alexa app and start device discovery. Alexa automatically discovers the supported Homey devices and adds them to your smart home.
After this, your Zigbee devices appear in the Alexa app without any additional pairing steps. The devices remain paired only with Homey. All Zigbee communication between devices and Homey runs locally over the Zigbee network.
How the connection works
  2. Amazon Alexa connects to Homey
    Alexa communicates with Homey, not with Zigbee devices directly.
  3. Homey forwards commands
    When you control a device with Alexa, Homey translates the command and sends it to the Zigbee device.
Once exposed, Zigbee devices usually appear in Alexa as standard smart home devices, such as:
  • Switches and plugs
You can:
  • Assign devices to rooms
  • Use them in Alexa routines
What to keep in mind
A few important points:
  • Not all Zigbee features are available in Alexa
Use Amazon Alexa for voice control and simple routines and Homey for automation and logic.
In short
Homey exposes them by making them visible and controllable in Alexa, while keeping all Zigbee communication and automation inside Homey.
Amazon Alexa becomes another way to interact with your devices and Homey stays in control.
