Post mortem API outage
Local connectivity
Problem summary
- AWS drops connections (still investigating why this happens)
 - No exponential back-off for reconnecting in Homey Pro
 - No rate-limit on connecting Homey Proʼs
 - Bug in v8 app when API server is down
Immediate actions taken
- Add exponential backoff to Homey Pro
 - Add rate-limit to our connect servers
 - Fix bug in v8 app
Long term actions
- Add more testcases to the mobile app for local connectivity
 - Improve customer communication in case issues like this arise
