Control Z-Wave devices via Apple Home with Homey
Z-Wave devices don’t connect directly to Apple Home. To control Z-Wave lights, switches, or sensors in Apple Home, you need a smart home hub that supports Z-Wave and can make those devices available to Apple’s platform.
Homey acts as that bridge, exposing Z-Wave devices to Apple Home. Homey stays in control of the devices and Apple Home becomes an additional way to control them.
What you need
To control Z-Wave devices via Apple Home, you need:
- A Homey Pro with built-in Z-Wave support, or a Homey Bridge to enable Z-Wave for Homey Pro mini, Homey Cloud, or Homey Self-Hosted Server.
- One or more Z-Wave devices paired with Homey
- An Apple ID and the Apple Home app
Z-Wave devices must always be paired with Homey first, before they are added to Apple Home.
What “exposing devices” means
When Homey exposes a Z-Wave device to Apple Home, it means Homey shares that device with Apple Home.
The device:
- stays paired with Homey
- is still controlled by Homey
- becomes visible in Apple Home
Apple Home does not communicate with Z-Wave devices directly. All commands go through Homey.
A simple way to think about it is that Homey translates between Z-Wave and Apple Home.
How to expose Z-Wave devices to Apple Home with Homey
Z-Wave devices don’t pair directly with Apple Home. Instead, Homey exposes supported Z-Wave devices to Apple Home using the HomeKit experiment.
The process works like this:
1.Set up the Z-Wave device in Homey
Add and include the Z-Wave device in Homey using the standard Z-Wave inclusion process. Once paired, Z-Wave communication between the devices and Homey runs locally over the Z-Wave network and creates a Homey device that represents it.
3. Add Homey to Apple Home
4. Devices sync automatically
After pairing, Apple Home imports compatible Homey devices. Supported Z-Wave devices appear as HomeKit accessories, such as lights, switches, sensors, or thermostats—depending on device capabilities.
5. Exclude devices if needed
After this, you can control Z-Wave devices from the Apple Home app or using Siri. The devices remain paired only with Homey, and all Z-Wave communication continues to run locally through Homey—no additional pairing or configuration is required in Apple Home.
How the connection works
- Z-Wave devices connect to Homey
Homey acts as the Z-Wave hub and controls the devices locally. - Apple Home connects to Homey
Apple Home communicates with Homey, not with Z-Wave devices directly. - Homey forwards commands
When you control a device in Apple Home, Homey translates the command and sends it to the Z-Wave device.
What you can do in Apple Home
Once exposed, Z-Wave devices usually appear in Apple Home as standard accessories, such as:
- Lights (on/off, dimming, sometimes color)
- Switches and plugs
- Sensors (for status and simple automations)
You can:
- Control devices in the Apple Home app
- Use Siri voice commands
- Assign devices to rooms
- Include them in scenes and basic automations
What to keep in mind
A few important points:
- Z-Wave devices must stay paired with Homey
- Not all Z-Wave features are shown in Apple Home
- Advanced automation and logic stay in Homey
- Removing a device from Homey also removes it from Apple Home
In short
Z-Wave devices can’t connect directly to Apple Home.
Homey exposes them by making them visible and controllable in Apple Home, while keeping all Z-Wave communication and automation inside Homey.
