Best Buy Guides Smart Plugs
Best Buy Guide
Smart Plugs
Best Buy Guide
Smart Plugs
Discover the Best Smart Plugs for Your Smart Home.
Whether you're looking to control lighting, manage appliances remotely, or improve energy efficiency, smart plugs are an easy and straightforward way to get the most out of your Homey-powered smart home.
However, choosing the right smart plug can be confusing and overwhelming, especially for novice users. That's why we've researched it for you, hoping to simplify and clarify things.
In this Best Buy Guide, we explore the best smart plugs of 2024 that are fully compatible with your Homey ecosystem. We selected these smart plugs based on their reliability, ease of integration, features, and positive user feedback.
Choosing the Right Smart Plug
When choosing smart plugs for your Homey, there are a few key points to consider and differentiate between. Depending on your intent and purposes, you might need one model more than another. Here are some key characteristics to consider when choosing a smart plug.
Maximum Power Rating
A plug with a lower max current (10A) will do just fine for simpler things like lights and small devices. If you control high-power appliances like dishwashers, you will usually need a plug capable of handling inductive loads (16A).
Energy Metering
Decide whether you need to keep track of the energy consumption of connected devices and appliances.
Size and Shape
Smart plugs come in different shapes and sizes. Carefully consider the dimensions and form of each so you avoid issues like covering adjacent outlets.
Price
Smart plugs save you money in the long run, but deploying many can quickly add up. When deciding, consider the price-to-features correlation introduced in this Best Buy Guide.
BrandModelProtocolMaximum CurrentEnergy MeteringPrice
Aqara Brand LogoAqaraSmart PlugZigbee10A, 2300W€29.99
eve table iconEveSmart PlugThread11A, 2500W€39.95
fibaro-brand-logo-bbgFibaroWall PlugZ-Wave11A, 2500W€59.95
frient-brand-logo-bbgFrientSmart Plug Mini 2Zigbee16A, 3840W€38.95
ikea-brand-logo-bbgIKEATRETAKT PlugZigbee16A, 3680W€7.99
innr-brand-logo-bbgInnrSmart PlugZigbee16A, 3680W€24.99
Meross IconMerossSmart Plug MiniMatter16A, 3680W€19.99
Onvis IconOnvisS4EU Smart PlugThread16A, 4000W€24.99
philips-hue-brand-logo-bbgPhilipsHue Smart PlugZigbee10A, 2300W€34.99
Popp IconPOPPOutdoor PlugZ-Wave16A, 3500W€55.00
qubino-brand-logo-bbgQubinoSmart Plug 16AZ-Wave16A, 3840W€55.99
shelly-brand-logo-bbgShellyPlus Plug SWi-Fi12A, 2500W€19.90
tapo-brand-logo-bbgTP-LinkTapo Smart PlugMatter16A, 3680W€24.90
Aqara Smart Plug
Available at €29.99
Shop now
Aqara Smart Plug
  • Energy metering
  • Zigbee router
  • Overload protection
  • Flame-retardant body
  • Bulky
Homey Bridge
Homey Pro
If you are looking for a capable Zigbee smart plug with power metering features, the SP-EUC01 model from Aqara is a great pick. Rated at 2300W, it can control anything you attach within its rated limit. If you somehow go over the max current rating, the plug has overloading and overheating protection mechanisms — automatically turning off the smart plug before anything dangerous happens.
Connected with Homey, the Aqara wall plug will act as a Zigbee router and relay traffic from adjacent devices back to Homey Bridge or Homey Pro — solidifying and extending your mesh network.
The Aqara model is a bit larger and bulkier compared to other brands, and although it won't obstruct neighboring outlets, it's an important factor to consider when making your pick.
Eve Energy Smart Plug
Available at €39.95
Shop now
  • Matter smart plug
  • Thread router
  • Fast response times
  • No energy metering (yet)
Homey Pro
The Eve Energy Smart Plug is part of the next generation of smart home devices that leverages the latest Matter standard and Thread communication technology to enhance the smart home experience.
Even though Thread is still very young, the Eve Energy smart plug is fully compatible with your Homey Pro. As an FTD (Full Thread Device), this plug acts as a repeater in your Thread network, relaying traffic from battery-powered end devices like motion, door and window, or temperature and humidity sensors back to your Homey Pro.
The plug is suitable for controlling various devices, from night lamps to kitchen dishwashers. If the power draw exceeds 11A or 2500W, a built-in fuse turns off the relay, safeguarding the plug and the connected appliance.
The Eve Energy Smart plug also supports energy metering, so you can always get an overview of the power draw and create flows based on the reading. The Matter specification does not include this functionality, but an upcoming update should add it.
Fibaro Wall Plug
Available at €59.95
Shop now
Fibaro Wall Plug
  • Energy metering
  • Z-Wave router
  • High-quality build
  • LED load indicator
  • Expensive
Homey Bridge
Homey Pro
If you prefer using Z-Wave devices, the Fibaro wall plugs are great for strengthening your network stability and overall health. Fibaro is a well-known top-tier Poland brand that uses the Z-Wave communication protocol for most of its products.
The Fibaro Wall Plug supports a maximum load of 2500W or 11A, enough to connect most domestic appliances. An overload protection switch turns off the plug when it exceeds the maximum current rating.
This premium plug also supports power metering, giving you an overview of the connected device's energy consumption. A built-in LED ring indicates the current load and operating mode value. You can even control this visually appealing set of LED lights from a Flow. The only real drawback of Fibaro wall plugs is their price tag — definitely more than other comparable models.
Frient Smart Plug Mini 2
Available at €38.95
Shop now
  • Energy metering
  • Zigbee router
  • Very small
  • High-power rating
  • Pricey
Homey Bridge
Homey Pro
Frient Smart Plugs top the list of Zigbee smart plugs for any smart home, standing out with their compact design. The Smart Plug Mini 2, in particular, measures only 41mm in diameter, which makes it the smallest smart plug in our buying guide.
Despite its small size, the Mini 2 can handle a maximum load of up to 16A or 3680W. This means it's suitable for connecting minor gadgets and major appliances - such as refrigerators, tumble dryers, and washing machines.
The Frient Smart Plug Mini 2 also has a power meter, which tracks the consumption of whatever you decide to connect. If your appliance draws more power than the plug can handle, a built-in overload protection mechanism immediately turns off the plug. This model costs more than similar plugs, but its feature set and miniscule footprint justify its price.
IKEA TRETAKT Plug
Available at €7.99
Shop now
IKEA TRETAKT Plug
  • Simple functionality
  • Very affordable
  • Zigbee router
  • Bulky
Homey Bridge
Homey Pro
If you want an affordable Zigbee smart plug with simple toggle functionality, look no further than the newly released IKEA TRETAKT Plug. Priced at €7.99, these IKEA plugs are ideal for mass deployment in your smart home.
The attractive pricing of TRETAKT plugs makes them an excellent option for expanding and strengthening your Zigbee network since they function very effectively as Zigbee routers. This smart plug's maximum current rating is 16A or 3680W, which is more than enough for controlling large appliances like washers, refrigerators, or heaters.
The IKEA TRETAKT plug doesn't have energy metering capabilities, so if you want to measure power consumption, you should skip this one. At 9 cm long, it's also the largest smart plug on this list, which you should consider when buying.
Innr Smart Plug
Available at €24.99
Shop now
Innr Smart Plug
  • Energy metering
  • Zigbee router
  • High power rating
  • Larger than most
Homey Bridge
Homey Pro
Innr is another reputable brand producing high-quality Zigbee smart devices. Of their range of smart plugs, we've chosen the SP 240 model as a top pick for several reasons.
This model can handle loads of up to 16A and accurately measure the energy consumption of whatever gadget you plug in. It integrates well with Homey and Homey Pro, pushing its power metering data over Zigbee to your hub.
Further, the device acts as a Zigbee router, improving your network's overall performance and stability. Measuring 52x52x82mm, it's not the smallest smart plug on our list, but it will not cover adjacent outlets.
Innr also produces an IP44-rated, waterproof 10A outdoor smart plug, model OSP 210. This plug uses Zigbee and works with your Homey Bridge or Homey Pro.
Meross Matter Smart Plug
Available at €19.99
Shop now
  • Matter smart plug
  • Very affordable
  • High power rating
  • Questionable build quality
Homey Pro
The Meross Smart Plug model MSS315 is a Matter-enabled wall plug designed for easy use and simple smart home integration. This model uses Wi-Fi as the underlying communication protocol, although the onboarding process to your Homey Pro is done through Bluetooth using your mobile device.
Rated at 16A or 3680W, the Meross Smart Plug can control high-power appliances without issues. The pairing button doubles as a status indicator, changing color depending on the current load.
The Meross Smart Plugs are very affordable, considering they support Matter, going around for €19 each. While their build quality is decent, it does not rank among the highest in this list.
Onvis S4EU Smart Plug
Available at €24.99
Shop now
  • Matter smart plug
  • Interesting design
  • Affordable
  • High power rating
Homey Pro
The Onvis S4EU Smart Plug is a budget-friendly Matter smart socket that uses the Thread communication protocol to talk to your Homey Pro. Like other Thread plugs on our list, it can extend your network by acting as a signal repeater for neighboring devices.
The plug features a very interesting dual-color design, complimented with a small button with an LED status indicator. It's not the smallest plug, but it's not bulky enough to cause issues when installed on dual sockets.
The Onvis S4EU Smart Socket is not capable of energy metering. However, it can handle loads of up to 16A or 4000W, which makes it an excellent choice for controlling large domestic appliances.
Priced at €24.99, it's already quite wallet-friendly, but when bought in bulk, it becomes the most cost-effective Matter-over-Thread smart plug, coming in at just €18.25 per unit.
Philips Hue Wall Plug
Available at €34.99
Shop now
  • Zigbee router
  • High power rating
  • Reliable
  • Low current rating for the price
Homey Bridge
Homey Pro
The latest Philips Hue Wall Plug model can communicate using Bluetooth and Zigbee. Although it can be controlled through the Hue Bridge, using Zigbee directly is recommended for your Homey ecosystem for reliability and mesh networking purposes.
Philips Hue smart plugs are fully supported in Homey and Homey Pro and are considered a top-tier pick among enthusiasts. The Hue wall plugs can control various devices within their 10A current limit, such as lamps, speakers, or other small to medium-sized appliances.
Their square-ish shape matches the standard EU sockets' design, making these smart plugs fit together seamlessly.
POPP Outdoor Plug
Available at €55.00
Shop now
POPP Outdoor Plug
  • High-power rating
  • Energy metering
  • Z-Wave router
  • Weather resistant
  • Bulky
  • Expensive
Homey Pro
Homey Bridge
If you need a high-power, weather-resistant smart plug for outdoor use, consider the POPP 3500W model. It uses Z-Wave to communicate with Homey Bridge or Homey Pro and acts as a network router, relaying network traffic from nearby devices.
The POPP Outdoor Plug is IP44-rated and capable of withstanding dry and humid conditions and water splashes from any direction. It has a protective lid that covers the plug when it's not in use. If you have an outdoor pool with a pump that you want to control, this plug is a perfect choice.
It's also equipped with a built-in energy meter, which gives you insight into the power consumption of the connected device. An indicator LED mounted on the front lets you glance at the plug's current status from a distance.
Once integrated into Homey, you can toggle the smart plug, monitor the energy usage, and remotely reset the total consumption the plug has recorded. The button mounted on the front can also be used for toggling, retaining the manual control of this wall plug.
Although designed for outdoor use, the plug is large. Measuring 152x60mm in height and width and 114mm deep, the plug is bulky and unsuitable for some applications. Its high power rating and weather resistance significantly raise the price of the POPP Outdoor Plug, making it one of the more expensive plugs on our list.
Qubino Smart Plug 16A
Available at €55.99
Shop now
  • Durable
  • Z-Wave router
  • Very Reliable
  • Expensive
  • Unattractive design
Homey Bridge
Homey Pro
If you are in the market for a trusted brand's heavy-duty smart plug, consider the Qubino 16A Smart Plug. Qubino is a Slovenian brand with a large product portfolio that focuses almost exclusively on Z-Wave devices.
Equipped with overload and overheating protection, the device automatically shuts off the relay. If the load exceeds 16.1A for over 5 seconds, it activates a red LED and sends an "Overcurrent detected" notification.
The Qubino Smart Plug has a depth of 75mm, which makes it relatively large and bulky. This aspect might be forgivable in certain applications if not for the plug's notably unappealing appearance.
The dependability and stability offered by the Qubino Smart Plug to your smart home come at a premium, as this plug is pricier than others on our list.
Shelly Plus Plug S
Available at €19.90
Shop now
Shelly Plus Plug S
  • Affordable
  • Compact
  • Slower response times
Homey
Homey Pro
The Shelly Plus Plug S is a highly versatile and intelligent plug designed to enhance home automation systems like Homey and Homey Pro. Rated at 12A or 2500W, this smart plug is in the middle of the pack compared to others on this list, at least regarding the maximum power rating.
The Plug S efficiently tracks the energy usage of attached devices and visually represents the current load with an attractive color LED indicator. If you find it distracting, there is a "Night mode" setting you can schedule, lowering brightness or turning off the light completely.
Besides Wi-Fi, the Shelly Plug's main communication protocol, the device is also outfitted with Bluetooth, which is intended for software updates and debugging.
As a side note, Shelly also produces a 3000W Z-Wave smart plug with energy metering for the UK market, named Shelly Qubino Wave Plug UK, which is fully supported by Homey.
TP-Link Tapo Matter Smart Plug
Available at €24.90
Shop now
  • Matter smart plug
  • High-power rating
  • Affordable
Homey Pro
If you have decided on a Matter-enabled smart plug, the Tapo P110M is another model from TP-Link that you can use to future-proof your smart home with the latest communication protocol. Homey Pro is fully compatible with Matter-enabled devices, so the P110M can be effortlessly integrated over Wi-Fi into your existing setup.
This plug is rated 16A, so it can safely be used with high-power appliances like dishwashers, washing machines, and tumble dryers. It's rectangle-shaped instead of round, which might appeal more to certain users.
Even though this smart plug supports energy metering, the Matter specification currently does not. A future update should enable this feature for all Matter controllers, including your Homey Pro.
Simpler Alternatives
If you're not looking for energy metering or other advanced features highlighted in our top picks, a basic 433MHz smart plug with simple on/off functionality might suit your needs. These plugs are small, barely noticeable, and usually very affordable.
We recommend considering Trust Smart Home, Telldus, Nexa, or Dio smart plugs, which all work over 433Mhz with Homey Bridge and Homey Pro.
Final Thoughts
Wrapping up our Best Buy Guide for 2024's top smart wall plugs, it's evident that these devices are crucial for upgrading your smart home. They simplify controlling lights, managing appliances, and boosting energy efficiency in any Homey-enabled smart home. We've showcased various models known for their seamless integration with Homey, dependable performance, and strong user satisfaction.
When choosing a smart plug, consider the factors outlined in this guide, such as maximum power capacity, energy metering capability, physical size and shape, and price-to-features, to get the right plug for your needs.
