Smart Light Bulbs
Best Buy Guide
Smart Light Bulbs
Discover the Best Smart Bulbs for your Smart Home.
Choosing smart lights bulbs
  • Connectivity: Prioritize bulbs with reliable wireless connectivity protocols such as Matter (Thread) or Zigbee to strengthen your home mesh network.
  • Brightness and color control: Assess whether dimmable or color-controllable bulbs are necessary for your needs. Sometimes a simple on/off light bulb will do just fine (e.g., hallway).
  • Quality: Consider the integrity of the brand producing the smart bulbs to ensure a certain level of quality. Opt for reputable brands highlighted in our Best Buy Guide.
  • Energy efficiency:  Smart light bulbs vary in their energy efficiency, which can affect both your electricity bill and environmental impact. Look for bulbs with high efficiency ratings and avoid exceeding your necessary wattage.
  • Price: With a standard home potentially requiring between 10 to 50 light bulbs, costs can add up quickly. Consider the prices highlighted in this article to stay within your budget.
BrandModelsProtocolPrice
IKEATradfri Smart LightingZigbeeFrom €7.99
Kasa IconTP-LinkKasa Smart Light BulbsWi-FiFrom €14.99
Matter Brand IconNanoleafEssentials Light BulbsThreadFrom €19.99
Philips HueWhite and Color AmbianceBluetoothFrom €29.99
Govee Smart LED Bulbs
Available at €12.99
Shop now
  • Affordable
  • Vibrant colors
  • Suitable as ambient lights
  • Low maximum brightness
Homey Pro
Ikea Tradfri Smart Lighting
Available at €7.99
Shop now
  • Affordable
  • Great whites
  • Wide range of light bulbs
  • Mediocre color spectrum
Homey Pro
Homey Bridge
Ikea's Tradfri product line offers a diverse selection of ambient lights, ceiling lights, lamps, and light bulbs. They provide a cost-effective solution for transforming your home lighting into a smart system, particularly when purchased in bulk.
Within Ikea's smart light bulb range, you'll find various options, including basic dimmable bulbs, RGB bulbs, spotlights, globe-shaped bulbs, and filament bulbs reminiscent of traditional lighting.
The Tradfri lights use Zigbee to communicate with your Homey Bridge or Homey Pro directly, skipping the Tradfri gateway completely. The IKEA Tradfri app enables simple On/Off toggles, temperature and brightness control as well the ability to adjust hue and saturation of RGB bulbs.
While the white and warm white illumination beaming at 1000 lumens of the Ikea Tradfri bulbs is great, they have a mediocre color rendering index, with colors feeling very pale.
Innr Smart Lighting
Available at €9.99
Shop now
Innr Smart Lighting
  • Very affordable
  • Long life span
  • Zigbee router
  • Not suited for large rooms
Homey Pro
Homey Bridge
Available at €14.99
Shop now
  • Good build quality
  • Great CRI
  • Low energy consumption in standby
  • Tedious Wi-Fi setup process
Homey Pro
Homey
Kasa Smart Bulbs are part of TP-Link’s Kasa Smart Home brand, which includes various devices like plugs, cameras, motion sensors, switches, LED strips and other smart devices. Their light bulb range includes basic dimmable bulbs and multicolor RGB bulbs of up to 1000 lumens.
Their high color rendering index (CRI) provides more attractive and brighter colors to help you see the true color spectrum throughout your home. This is complemented through a fine grain dimmable range of 1-100%, which introduces no choppiness or flickering when controlled through Homey.
What sets Kasa apart from competitors is their bulb’s low power consumption of just 0.2W when in standby mode. Since Wi-Fi is very battery hungry, this is a feature that needs to be noted and commended.
TP-Link Kasa bulbs need to be onboarded through the Kasa Smart mobile app installed on your phone. You need to create an account with an email and password, accept their terms of use and then find your way through a thicket of menus until you finally make it to the correct screen to select your bulb type. This results in a tedious setup process when compared to other brands, as simply scanning a QR code is concept unknown to Kasa apparently.
Once integrated in Homey, the Kasa Light Bulbs work perfectly well, where you can change color, set the temperature, hue, saturation and dim/brighten the bulb.
LIFX Smart Lights
Available at €25.99
Shop now
LIFX Smart Lights
  • High-quality build
  • Excellent CRI
  • Night Vision Infrared model
  • Pricier than competition
Homey Pro
Homey
Available at €19.99
Shop now
  • Matter light bulbs
  • Thread router
Homey Pro
Available at €29.99
Shop now
  • Premium quality
  • Durable and reliable
  • Expensive
Homey Pro
Homey
Sengled Smart Bulbs
Available at €14.99
Shop now
Sengled Smart Bulbs
  • Great quality
  • Versatile portfolio
  • Budget models available
Homey Pro
Homey Bridge
Among their full stack of light bulb choices, lies an interesting gem of a device: a motion-activated light bulb, with a built-in PIR motion sensor! This model automatically turns on when it detects motion within its huge range of 12 meters.
Available at €14.40
Shop now
  • Affordable
  • Built-in energy meter
Homey Pro
Homey
Wiz Connected Smart Bulbs
Available at €10.99
Shop now
  • Great build quality
  • Vibrant colors
Homey Pro
Yeelight Smart Bulbs
Available at €15.95
Shop now
  • Great colors
  • Music sync
  • Limited models variety
Homey Pro
Homey
About Matter Light Bulbs
Summary
