What is Matter?
Matter at a Glance:
- Communication standard for smart home devices.
- 1.0 version launched on October 4, 2022, after being postponed twice.
- Standardized set of commands, so devices from different manufacturers can talk to each other.
- Runs on top of IP networks, using either Thread, Wi-Fi, or Ethernet.
- Uses Security by Design and Zero-Trust.
- Runs locally – typically connects to the cloud via a Matter hub.
- Exists alongside other smart home standards like Zigbee, Z-Wave, and 433MHz.
- Battery life and range dependent on wireless networking technology.
- Coordinated by a Matter hub, like Homey Pro or Homey Pro mini
What is Matter?
Matter uses Thread, Wi-Fi and Ethernet as networking technologies underneath. It can use Bluetooth for pairing, or 'commissioning' devices to your Matter controller. Splitting the networking technology and protocol sets Matter apart from technologies like Z-Wave and Zigbee, as these technologies integrate the two.
Why Matter Matters?
Matter is no longer an emerging technology. It is the established foundation rapidly unifying the smart home market today. Its primary significance lies in solving the historical problem of platform fragmentation. The standard ensures that devices from any major manufacturer (be it Samsung, Amazon, Google, or Apple) will work seamlessly with all major smart home ecosystems.
Finally, Matter provides a critical bridge between old and new technology. Many established manufacturers, such as Philips Hue, use their existing hubs as Matter Bridges. This allows millions of older Zigbee devices to be immediately integrated and controlled by modern Matter controllers. This ensures you do not have to replace your entire setup overnight. Choosing Matter-certified products today means investing in a stable, fast, and future-proof smart home where all components speak the same language.
This is why Matter is important: it is not replacing your smart home — it is adding a universal, local, future-proof layer on top of what already exists.
Matter Basics: How It Works
All of these networks are local, which means they are governed and controlled within your home. Most Matter hubs include a bridging option to the internet. Some Matter devices that are based on Ethernet or Wi-Fi might connect to the cloud / the internet themselves in a non-Matter way though. This may add a security risk that pure local devices do not have.
It's important to note that Matter devices cannot always simply talk to each other. While Ethernet and Wi-Fi devices are generally on the same network, Thread devices form a different network. A Thread border-router is needed to bridge the gap between Thread and LAN devices in a smart home.
Thread itself is a low-power and low-latency wireless mesh networking technology. It uses IP, which is why Matter can run on it. Thread is a relatively new technology, that has been built on the foundations of Zigbee. Thread can be found in battery-operated devices requiring the highest energy efficiency like sensors and door-locks or simple mains-powered devices like smart plugs or light bulbs.
In short:
- Matter devices can easily talk to each other thanks to their unified application layer.
- Matter can use Thread, Wi-Fi and Ethernet as physical communication layer.
- Not all of these communication layers are automatically compatible with each other (LAN vs Thread).
- Matter devices on Thread make use of Mesh networking.
What is Mesh Networking
A mesh network is essentially a network where multiple devices in the network take on the role of a router, or repeater. Rather than only sending signals back to the originator, they repeat signals and forward them to the other network devices within range. These, in turn, can relay the signals further. This 'signal-hopping' gives mesh networks more range and more reliability than traditional 'star networks'. These networks expand automatically when you add more devices. Together, they build a stronger and more reliable network.
Matter devices only are part of a mesh network if they use Thread as their wireless technology. Most Matter devices are on Wi-Fi and therefore do not create a mesh network.
What’s in a Matter Network?
The Matter hub is the brain of your network. The coordinator can connect smart devices, set permissions, allow other devices access, and coordinate your network. The Matter hub also delivers the interfaces you use to control your Matter network. This can be interfaces for automation, like Homey Flow, Energy data like Homey Energy and Homey Insights, or simply a control-interface. The Matter hub is also the gateway to the internet for the Matter network. And some smart home hubs, like Homey Pro, connect your Matter devices to devices that use other protocols, like Zigbee, Z-wave, Infrared or 433MHz.
Briefly mentioned before – not all Matter devices can automatically talk to each other. This has to do with the fact that LAN, which is your home network ran on Ethernet and Wi-Fi, is a different network than Thread.
They work fundamentally different. Let's compare the wireless versions: Thread is a mesh network built for low power consumption and bandwidth, while Wi-Fi is a star-topology network built for high bandwidth (and higher power consumption).
Sometimes, a Matter hub is also a Thread border-router. This is the case if the Matter hub includes Thread itself as well, like Homey Pro and Homey Pro mini.
These devices are either the destination or source of data transmitted. Often powered by a small battery, this device does not repeat or forward any signals. I.e., this is the end of your network. In most cases, standard Matter devices will either be on LAN (like Wi-Fi) or will be Thread Mesh Extenders. Unless you choose battery-operated devices such as wireless lights, simple switches, etc. These are typically end-devices because that allows them to work much longer on one battery load.
Which Devices Support Matter?
- Lighting: On/Off lights, Dimmable lights, Color Temperature lights, and Extended Color (RGB) lights.
- Electrical/Actuators: On/Off Smart Plugs/Outlets, Dimmable Plug-In Units, Mounted On/Off Switches, Dimmable Load Controls, and Pumps/Water Valves.
- HVAC & Climate: Thermostats, Heating/Cooling Units, Fans, Air Purifiers, Room Air Conditioners, and Water Heaters.
- Security & Closures: Door Locks, Window Coverings (Blinds/Shades), Contact Sensors, Motion Sensors, Occupancy Sensors, and Door Lock Controllers.
- Sensing: Temperature Sensors, Humidity Sensors, Pressure Sensors, Light Sensors, Flow Sensors, Air Quality Sensors, Water Leak Detectors, Rain Sensors, and Smoke & Carbon Monoxide (CO) Alarms.
- Media: Televisions, Basic Video Players, Casting Video Players, Speakers, and Video Remote Controls.
- Appliances: Refrigerators, Dishwashers, Laundry Washers/Dryers, Ovens, Cooktops, Microwave Ovens, and Extractor Hoods.
- Robotics: Robotic Vacuum Cleaners.
- Energy & Infrastructure: Electric Vehicle Chargers (EVSE), Energy Sensors, Heat Pumps, Battery Storage/Solar Power Systems, Thread Border Routers, and Matter Bridges (for connecting non-Matter devices).
- Manufacturer-Specific Advanced Features: This is the most common limitation. While a device like a smart light bulb works with Matter (on/off, color control), its rich, unique features—such as dynamic lighting scenes, specific energy monitoring data, specialized security modes, or complex appliance diagnostic readouts—are often not exposed to third-party ecosystems via the Matter standard. You still need the original manufacturer's app to access them (e.g., Hue's Entertainment Mode, or advanced thermostat scheduling).
- Security Camera/Video Doorbell Intelligence: While Matter 1.5 officially introduced native support for cameras (including live video/audio streaming and pan-tilt-zoom control), the standard does not handle video analysis or intelligence. [Inference] This means features like AI-based person/pet recognition or triggering automations based on detected events still rely on the manufacturer's own software and cloud services
- Highly Specialized Systems: Some niche or proprietary multi-component audio/video systems (like specialized multi-room audio) or high-end integrated home security systems (beyond basic locks and sensors) may not yet have complete, feature-rich Matter integration and often rely on their own APIs or protocols for complex functionality.
Why Use Matter?
Interoperability
Most Matter devices work together no matter which brand makes them (mind the LAN / Thread difference though!). However, this only applies to all Matter devices, not to all the other smart home devices on other technologies. This makes the interoperability-claim a bit similar to the same one from Zigbee and Z-wave at the moment. Matter has some momentum and a lot of manufacturers behind it, although the first companies are also dropping out again. Its full interoperability claim has yet to come true as well. In the end, universal smart home hubs that combine Matter and other technologies will always be the most interoperable.
Security
Simplified User Experience
Most Matter hubs, like Homey Pro, feature intuitive interfaces for smart home control and automation. Also, the Matter protocol includes a simple pairing process.
Local by design
Power-Efficient
Because Thread is a part of the Matter protocol, Matter devices can be very power-efficient. Thread end-devices use very little energy when in standby, which greatly reduces electric usage and improves battery life where relevant. Again, the same holds for Zigbee and Z-Wave devices.
Multi-admin Control
Disadvantages
The biggest issue is that Matter often only exposes basic device functions (e.g., on/off, dimming) to third-party ecosystems (like Google Home or Apple Home), while advanced, proprietary features (like energy monitoring, specific color effects, or advanced automation settings) remain locked in the manufacturer's native app. This forces users to still juggle multiple apps.
Limited Device Categories
Thread Network Dependency
New Matter-enabled devices often require more powerful chipsets, potentially making them more expensive than older Zigbee or Z-Wave counterparts. [Inference] This makes retrofitting older, existing hardware difficult or impossible, forcing users to buy new devices to adopt the standard.
Homey as a Matter Controller
Homey Pro is one of the most complete Matter hubs available. It supports eight major smart home technologies, including Zigbee, Z-Wave, 433MHz, Infrared, BLE, Wi-Fi, Thread — and, of course, Matter. This makes it uniquely positioned to bridge the gap between today’s mixed-technology smart home and tomorrow’s Matter-powered world.
Getting Started With Matter
Step 1: Choose a Matter hub. We obviously recommend Homey Pro or Homey Pro mini. It allows you to also stay flexible with regards to other smart home technologies.
Step 3: Setup your hub.
A truly comprehensive smart home hub, like Homey Pro, features a blend of protocols. The ideal hub or controller for your setup is one that can seamlessly manage and automate devices across all the technologies you choose to use.
Frequently Asked Questions
Is Matter secure?
