What is Matter?
What is Matter?
Explaining the World’s Latest Smart Home Standard.
Matter at a Glance:
  • Communication standard for smart home devices.
  • Coordinated by a Matter hub, like Homey Pro, Homey Pro mini or Homey Self-Hosted Server, all certified as Matter 1.5 controllers by the Connectivity Standards Alliance
What is Matter?
Why Matter Matters?
Homey-Pro-hub
Matter Basics: How It Works
Matter technology stack.
In short:
What is Mesh Networking
Mesh networking, like Thread, means nodes can relay signals, increasing the effective range.
What’s in a Matter Network?
The Matter hub is the brains of your network. The coordinator can connect smart devices, set permissions, allow other devices access, and coordinate your network. The Matter hub also delivers the interfaces you use to control your Matter network. This can be an interface for automation, like Homey Flow, Energy data like Homey Energy and Homey Insights, or a simple a control interface. The Matter hub is also the gateway to the internet for the Matter network. And some smart home hubs, like Homey Pro, connect your Matter devices to devices that use other protocols, like Zigbee, Z-Wave, Infrared or 433MHz.
Thread Network Topology
Homey Pro acts as a Thread Border Router, bridging Thread devices to IP networks
Sometimes, a Matter hub is also a Thread border-router. Homey Pro and Homey Pro mini include a built-in Thread Border Router and connect Matter-over-Thread devices to their own Thread network directly.
These devices are either the destination or source of data transmitted. Often powered by a small battery, this device does not repeat or forward any signals. I.e., this is the end of your network. In most cases, standard Matter devices will either be on LAN (like Wi-Fi) or will be Thread Mesh Extenders. Unless you choose battery-operated devices such as wireless buttons, simple sensors, etc. These are typically end-devices because that allows them to work much longer on one battery load.
Matter devices
Which Devices Support Matter?
Running Matter 1.5, Homey now supports a broad set of these categories out of the box, including EV chargers, heat pumps, solar panels, major household appliances, robot vacuum cleaners, speakers, sensors and window coverings. Homey plans to expand this list further as new Matter device categories and capabilities become available. Check the full list of supported devices for the current overview.
  • Manufacturer-Specific Advanced Features: This is the most common limitation. While a device like a smart light bulb works with Matter (on/off, color control), its rich, unique features—such as dynamic lighting scenes, specific energy monitoring data, specialized security modes, or complex appliance diagnostic readouts—are often not exposed to third-party ecosystems via the Matter standard. You still need the original manufacturer's app to access them (e.g., Hue's Entertainment Mode, or advanced thermostat scheduling).
  • Security Camera/Video Doorbell Intelligence: While Matter 1.5 officially introduced native support for cameras (including live video/audio streaming and pan-tilt-zoom control), the standard does not handle video analysis or intelligence. This means features like AI-based person/pet recognition or triggering automations based on detected events still rely on the manufacturer's own software and cloud services
  • Highly Specialized Systems: Some niche or proprietary multi-component audio/video systems (like specialized multi-room audio) or high-end integrated home security systems (beyond basic locks and sensors) may not yet have complete, feature-rich Matter integration and often rely on their own APIs or protocols for complex functionality.
Why Use Matter?
Interoperability
Most Matter devices work together no matter which brand makes them (mind the LAN / Thread difference though!). However, this only applies to all Matter devices, not to all the other smart home devices on other technologies. This makes the interoperability-claim a bit similar to the same one from Zigbee and Z-wave at the moment. Matter has some momentum and a lot of manufacturers behind it, although the first companies are also dropping out again. Its full interoperability claim has yet to come true as well.
In the end, universal smart home hubs that combine Matter and other technologies will always be the most interoperable. Homey takes this approach directly, bringing Matter devices together with Zigbee, Z-Wave, Bluetooth, Infrared and 433 MHz products, plus brand-specific local and cloud integrations, all in one system.
Security
Simplified User Experience
Most Matter hubs, like Homey Pro, feature intuitive interfaces for smart home control and automation. Setup is straightforward too. You can add Matter devices to Homey directly, without installing a brand-specific app first. Homey identifies the device and its available capabilities automatically, while dedicated Homey apps can add extra functionality on top when needed.
Local by design
Power-Efficient
Because Thread is a part of the Matter protocol, Matter devices can be very power-efficient. Thread end-devices use very little energy when in standby, which greatly reduces electric usage and improves battery life where relevant. Again, the same holds for Zigbee and Z-Wave devices.
Multi-admin Control
Disadvantages
Limited Device Categories
Thread Network Dependency
Homey as a Matter Controller
Homey Pro and Homey Pro mini are certified as Matter 1.5 controllers by the Connectivity Standards Alliance (CSA), the organization behind the Matter standard. Our Homey Self-Hosted Server supports Matter as well. Together, these products make Homey one of the most complete Matter hubs available today, supporting eight major smart home technologies, including Zigbee, Z-Wave, 433MHz, Infrared, BLE, Wi-Fi, Thread and, of course, Matter. This positions Homey to bridge today's mixed-technology smart home with tomorrow's Matter-powered world. Full certification details are available on the CSA product page.
Getting Started With Matter
Step 1: Choose a Matter hub. We obviously recommend Homey Pro, Homey Pro mini or Homey Self-Hosted Server, all certified Matter 1.5 controllers. Each one keeps you flexible with other smart home technologies too."
Step 3: Setup your hub.
A truly comprehensive smart home hub, like Homey Pro, features a blend of protocols. The ideal hub or controller for your setup is one that can seamlessly manage and automate devices across all the technologies you choose to use. With Homey Pro and Homey Pro mini now certified as Matter 1.5 controllers by the Connectivity Standards Alliance, Homey continues to bring new Matter devices together with the products people already own.
Homey Pro Matter hub
Frequently Asked Questions
Is Matter secure?
Is Homey Matter 1.5 certified?
Yes. Homey Pro and Homey Pro mini are certified as Matter 1.5 controllers by the Connectivity Standards Alliance. Certification details are available on the CSA product page.
Does Homey Self-Hosted Server support Matter?
Yes. Homey Self-Hosted Server supports Matter alongside Homey Pro and Homey Pro mini.
What changed with Matter 1.5?
Matter 1.5 expands the range of supported device categories. Running Matter 1.5, Homey now supports EV chargers, heat pumps, solar panels, major household appliances, robot vacuum cleaners, speakers, sensors and window coverings, with more categories planned as they become available."
