Heat Pump Smart Control with Homey: Flows, Zones and Comfort Rails
Your heat pump can do much more than just switch on and off. With the right rules, it runs more calmly, your home becomes predictably comfortable, and you shift consumption to moments that are financially favorable for you.
Homey is the brain that makes this possible. You create simple automations in everyday language, ensure your zones work together instead of fighting each other, and set "comfort rails" that protect what really matters: a pleasant home without the hassle.
One Director, Clear Signals
Homey Pro connects your entire energy ecosystem: your heat pump control, smart thermostat, temperature sensors, smart plugs, EV charger, solar panels, and even your SG-ready heat pump & boiler.
By plugging in the Homey Energy Dongle, you can read your consumption and feed-in live within Homey Energy. That data forms the anchor for your Flows. Instead of relying on guesswork, you control your home based on real conditions. You can see peaks and baseload usage, recognize when you are feeding energy back to the grid, and discover exactly how your heat pump responds to outdoor temperatures and setpoints.
Zones That Cooperate
A heat pump thrives on calm, consistent operation. You achieve that stability with zone heating that doesn’t get in its own way.
For example, you can give the living room a fixed comfort band while putting bedrooms in a softer, cooler profile. The hallway and landing are usually just transit zones; they don’t need to be warm all the time. With a smart thermostat and additional sensors, you assign each room its specific role.
Motion and presence sensors determine whether a zone is active, while open-window detection pauses heating temporarily to save energy. The result is a home that doesn’t chase half-degree adjustments and where the compressor can run longer at a gentle, efficient output.
Comfort Rails: Boundaries That Protect Your Daily Life
Think of "comfort rails" as your guardrails. You define what must always be right, regardless of energy prices, sun, or planning. These might include minimum temperatures per zone, quiet hours for devices, a maximum simultaneous power draw during cooking, and a minimum charge level for your car.
Within those boundaries, your smart home hub is free to optimize. You don’t lose comfort, but your system gets the room to make smart choices. It feels like the house is one step ahead of you, without ever working against you.
Pre-Heating When It Pays Off
The strength of Flows is that they let heating happen at the right time. On sunny afternoons or during cheap energy intervals, the living room can gently pre-heat so you need less top-up heat in the evening. You don’t make abrupt temperature jumps; rather, you let the thermal mass of your floors and walls do the work.
If you have solar panels, a simple rule is often enough: when feed-in via the P1 meter exceeds your threshold, the supply temperature may go up a bit within the comfort band. With a dynamic energy contract, you use the same principle on quarter-hour blocks. Your heat pump will then run harder mainly when electricity is abundant and cheaper, without you having to check charts every day.
Peak Shaving Without Micromanaging
The evening rush hour is notorious: cooking, lighting, entertainment, and maybe EV charging and hot water all happening at once. With peak shaving, you spread this load out.
You can let the EV charger automatically ramp down as soon as total power draw via the P1 meter exceeds your threshold. The dishwasher can politely wait until the induction hob is turned off. If you have a home battery, it may briefly help out during a peak. Meanwhile, your heat pump keeps running calmly because you aren’t forcing it to heat against the current during the busiest time of the day.
Example Flows That Give You Immediate Benefit
A simple pre-heat Flow: If feed-in via P1 stays above your threshold for more than ten minutes and it’s between 11:00 and 15:30, the zone temperature may go to the upper end of the comfort band. If feed-in drops or it gets too warm, the system returns to normal.
A peak shaving Flow: If total power usage in the home exceeds your limit, temporarily reduce the car’s charging power and postpone starting plan-able loads.
A tap water Flow: With sunny surplus or a low price, the boiler may get a boost, but never outside of your designated quiet hours.
Sensors That Make the Difference
Temperature sensors in key rooms give your control logic context. A humidity or CO₂ sensor can help decide where ventilation or a short open-window period is needed, so you don’t produce unnecessary heat while simultaneously venting it away.
Additionally, with a smart plug, you can measure auxiliary equipment such as circulation pumps or electric backup heating. This way, you see immediately in Homey Energy whether they are "dribbling along" efficiently with your heat demand or whether they would better fit into a separate time window.
Seasonal Profiles and Maintenance Moments
Your home in January needs different handling than in April. Therefore, create seasonal profiles that you can activate with a single switch. In winter, your comfort band is slightly tighter, and your pre-heat window sits earlier in the afternoon. In spring and autumn, you can widen the band and steer more often based on solar input.
Also, schedule maintenance moments as a Flow: a monthly notification with your average heat pump consumption, number of compressor starts, and any peak limit exceedances. Small, fixed rituals keep your system quiet and efficient.
Calm Over Perfection
You don’t have to chase the last percent of efficiency. The biggest gains come from calm control, low supply temperatures, a few well-chosen pre-heat windows, and clear comfort rails. Everything you add after that is just fine-tuning. Once a month, look at your graph in Homey Energy. Tweak a threshold if the season has changed, and let the system do its work.
How to Start Today
Plug the Homey Energy Dongle (P1 meter) into your smart meter and observe your pattern for a week. Connect your smart thermostat and add sensors to the living room and bedroom. Then, create:
- One pre-heat Flow based on sun or a cheap interval.
- One peak-shaving Flow for the cooking hour.
- One tap water Flow for your heat pump boiler.
Once these are in place, you can refine zones, add seasonal profiles, and optionally let your EV charger or home battery join in. You’ll notice your heat pump runs more quietly, your home is more evenly warm, and your consumption shifts to the moments that are most advantageous for you.
You don’t need to be an engineer to achieve this. You define rules in everyday language, Homey directs, and you keep the overview in a single app. Smart heating no longer feels like a project, but like natural comfort that becomes a little more efficient every day.
What does it mean that Homey Pro is the “director” of my heat pump?
Homey Pro links your thermostat, zones, sensors, P1 data, solar panels, tap water module, EV charger, and any home battery. This allows your heat pump to react to real conditions in the home, instead of relying on isolated timers or "blind" schedules.
How do zones help my heat pump run more calmly?
Zones ensure rooms don’t work against each other. The living room gets a strict comfort band, while bedrooms get a softer profile. Homey only activates zones when needed, so the compressor has to start less often and can modulate for longer periods.
What exactly are comfort rails?
Comfort rails are the fixed boundaries within which Homey may optimize: temperature bands, quiet hours, peak limits, minimum charge levels for your EV, and ventilation rules. They safeguard comfort and prevent Flows from making extreme choices.
How does pre-heating with Homey work in practice?
Pre-heating means subtly warming up within your comfort band when electricity is cheap or when your solar panels are generating a lot. As a result, your heat pump has to work less hard in the evening and therefore runs more efficiently.
Can Homey apply peak shaving without my heat pump suffering from it?
Yes. Homey first reduces your EV’s charging power, delays household appliances, and, if applicable, lets the home battery briefly help. Your heat pump keeps calmly modulating because it doesn’t have to compete with other heavy consumers for power.
How do I schedule hot water production smartly?
Use a heat pump boiler or tap water module and let Homey charge during the day with solar generation or low prices. Schedule anti-legionella cycles in a quiet window. This way, you avoid expensive or noisy night cycles.
Which sensors are most important for smart control?
Temperature sensors in the living room and bedrooms, optionally CO₂ or humidity readings for ventilation, and a smart plug to monitor auxiliary equipment. With these, Homey understands the context of your heating much better.
How do I know if my Flows are too busy or too complex?
If your heat pump starts to short-cycle (short starts/stops), shows too many temperature spikes, or your P1 graph displays many peaks, your Flows might be too complex. In that case, you are better off slightly widening comfort bands, increasing hysteresis, or bundling Flows into a single Advanced Flow.
Do I need to adjust settings every week?
No. Calm is key. Usually, a monthly check is enough: how is your consumption, how many compressor starts occurred, and does the behavior fit the season? Small seasonal adjustments are more effective than constant fine-tuning.
How do I start in the simplest way with smart control of my heat pump?
Start with P1 insight, set a comfort band per zone, and create one pre-heat Flow and one peak-shaving Flow. Then add hot water scheduling, seasonal profiles, and exception rules. Within a week, you’ll notice more calm, fewer peaks, and a more stable home.
