Control Z-Wave devices with Google Home using Homey
Z-Wave devices don’t connect directly to Google Home. To control Z-Wave lights, switches, or sensors with Google Home, you need a smart home hub that supports Z-Wave and can make those devices available to Google’s platform.
Homey acts as that hub. It connects to Z-Wave devices and exposes supported devices to Google Home. Homey stays in control of the devices. Google Home becomes an additional way to control them.
What you need
To control Z-Wave devices with Google Home, you need:
- A Homey Pro with built-in Z-Wave support, or a Homey Bridge to enable Z-Wave for Homey Pro mini, Homey Cloud, or Homey Self-Hosted Server.
- One or more Z-Wave devices paired with Homey
- A Google account and the Google Home app
Z-Wave devices must always be paired with Homey first, before they are added to Google Home.
What “exposing devices” means
When Homey exposes a Z-Wave device to Google Home, it means Homey shares that device with Google Home through its integration.
The device:
- stays paired with Homey
- continues to be controlled by Homey
- becomes visible in Google Home
Google Home does not communicate with Z-Wave devices directly. Commands are routed through Homey.
A simple way to think about it: Homey translates Z-Wave devices into controls Google Home understands.
How to connect Homey to Google Home
You don’t need to re-pair Z-Wave devices or change how they’re connected.
The process works like this:
- Pair Z-Wave devices with Homey
Make sure the Z-Wave devices you want to use are already added to Homey and working correctly. - Link Homey in the Google Home app
Open the Google Home app, choose Add / Set up device, select Works with Google, choose Homey, and allow Google to access your Homey account. - Sync devices to Google Home
After linking, Google Home automatically imports the supported Homey devices.
After this, your Z-Wave devices appear in Google Home without any additional pairing steps. The devices remain paired only with Homey.
How the connection works
- Z-Wave devices connect to Homey
Homey acts as the Z-Wave hub and controls the devices locally. - Google Home connects to Homey
Google Home communicates with Homey via the Homey cloud integration. not with Z-Wave devices directly. - Homey forwards commands
When you control a device in Google Home, Homey translates the command and sends it to the Z-Wave device.
Once exposed, Z-Wave devices usually appear in Google Home as standard smart devices, such as:
- Lights (on/off, dimming, sometimes color)
- Switches and plugs
- Sensors (for status and simple routines)
You can:
- Control devices in the Google Home app
- Use Google Assistant voice commands
- Assign devices to rooms
- Include them in Google Home routines
What to keep in mind
- Z-Wave devices must stay paired with Homey
- Not all Z-Wave features are available in Google Home
- Advanced automation and logic stay in Homey
- Removing a device from Homey also removes it from Google Home
Use Google Home for control and voice and Homey for automation and logic.
In short
Z-Wave devices can’t connect directly to Google Home.
Homey exposes them by making them visible and controllable in Google Home, while keeping all Z-Wave communication and advanced automation inside Homey.
Google Home becomes an additional way to interact with your devices and Homey stays in control.
