Discover the new Homey Portal
Home Automation 101: how it works & where to start
How it works
Home automation with conditions makes sure your home does exactly what you want
How to create home automation
Homey Flow for home automation
With Homey, you can easily create home automation Flows on your phone
Home automation on your phone
Home automation on your PC
home automation with Homey Flow for Web
Home automation on the big screen with Homey Flow for Web
