                Homey as a Smart Home Security System
Smart devices have transformed how we think about home security. Motion sensors, contact sensors, and smart locks can now work together with lighting, entertainment, and alarm systems to keep your home safe. Homey gives you the freedom to combine all these devices into a single smart home security system that fits your needs and proactively keep your home secure.
Smart Home Security At a Glance
- What is a Smart Home Security System?
 How does a smart home security system work and why is it important?
- The Main Roles of a Smart Security System
 What are the key functions that every smart security setup should cover?
- Health and Safety Devices in Smart Home Security
 Which devices protect your home from everyday risks beyond intruders?
- Building a Smart Security System with Homey
 Learn how to use your existing sensors as smart security devices in Homey
- Getting Started
 Learn what you need to start your Homey Smart Home Security System
A smart home security system combines traditional security hardware with smart home technology. Instead of relying on a closed alarm system or expensive security hardware, you connect your existing presence sensors, door/window sensors, cameras, locks, sirens, and lights to a smart home hub like Homey.
Homey ties everything together, monitors your home for potential threats, and reacts instantly when needed. A modern and capable smart home security system proactively protects your home from intruders, notifies you of suspicious activity, and takes preventive measures like automatically locking doors or turning on security lights.
Every effective smart security setup serves three main roles: detection, reaction, and prevention. Homey brings all of these together into one flexible platform that adapts to your needs.
Detection
The first step in protecting your home is knowing when something is happening. Motion sensors keep an eye on hallways or outdoor areas, while door and window contacts alert you the moment someone tries to enter. Vibration sensors take security a step further by catching forced entry attempts, such as glass breaking, while cameras add real-time awareness by providing live video or snapshots straight to your phone.
It is not just about intruders either, because smoke & carbon monoxide detectors, water leak sensors, or air quality monitors can all integrate with Homey to detect dangers that threaten your home and family. For instance, a Homey Flow can alert you instantly when smoke is detected in the basement, even when you are not home.
Reaction
Detection only matters if your system responds right away. With Homey, the same devices you use for everyday comfort can double as security tools. Lights can turn on brightly or flash when motion is detected, while Sonos or Google Nest speakers can play a loud siren to scare away intruders without needing extra hardware. These instant reactions make it clear that your home is not an easy target.
At the same time, Homey makes sure you are kept in the loop. Push notifications arrive on your phone the moment something happens. For example, if motion is detected in the living room while nobody is home, Homey can flash all the lights red and trigger a siren sound through your speakers at maximum volume, while sending you a notification at the same time.
Prevention
The strongest security systems do not just respond to incidents, they help stop them before they occur. Smart locks can automatically secure doors when you leave, ensuring that nothing is left unlocked. Curtains and blinds can move on schedules or based on sunset times, while lights can switch on in different rooms, making your home look busy even if it is empty.
Homey adds another layer by making these automations feel natural. Instead of rigid schedules, you can randomize the timing of lights or even switch on your TV at irregular intervals to simulate presence. For instance, when the last family member leaves, Homey can lock the front door, close the blinds, and turn on a smart lamp after sunset to give the impression that someone is still home.
Smart home security is not only about protecting against intruders. Many everyday risks come from accidents, hazards, or environmental factors inside the home. Modern smart devices can detect these problems early, notify you instantly, and even take automatic action to reduce damage or keep your family safe.
Fire and gas safety
Connected smoke detectors and carbon monoxide sensors provide early warnings when danger strikes. Instead of just sounding a siren, they can also notify you on your phone so you know immediately, even if you are away. With a simple Flow, smoke detection in the basement can trigger alarms on every speaker, turn on hallway lights, and send a push notification at once.
Water and flood protection
Water leak sensors placed under sinks or near appliances alert you to small drips before they become costly floods. They can also start Homey Flows, such as flashing a nearby light and closing a smart water valve when water is detected under the washing machine. This quick reaction can save you from expensive damage.
Air quality and wellbeing
Air quality monitors track pollutants, humidity, and temperature, helping you maintain a healthier home. Combined with Homey, they can switch on a purifier, dehumidifier, or simply notify you to open a window. A Flow that turns on the purifier when particulate levels rise ensures your air stays clean without you lifting a finger.
Homey is more than a smart home hub. It becomes the brain of your security system, connecting devices from different brands and giving them multiple roles. What makes Homey unique is that your devices do not just sit idle until something bad happens. The same motion sensor, light, or speaker you use every day can also serve as part of your security setup. Here is how it works in practice.
Using your existing sensors as security triggers
Most smart homes already have many sensors in place, and Homey makes them work double duty. For instance, a hallway motion sensor that normally switches on the lights when you arrive home can also trigger alarms and notifications if movement is detected while the house is empty. Door and window contacts can notify you if someone opens a door at the wrong time, while vibration sensors can detect glass braking and catch forced entry attempts.
Using your smart devices as deterrents
With Homey, your existing smart devices can become powerful intruder deterrents. Lights can flash red, curtains can open unexpectedly, or all speakers in the house can play a loud siren to scare off intruders. A Sonos speaker that usually plays music can instantly become part of your alarm system. Even a simple smart bulb can double as a warning light. By reusing devices you already own, Homey makes your security system cost-effective and highly flexible.
Staying informed wherever you are
A key part of any security system is knowing what is happening in real time. Homey sends instant push notifications to your phone whenever a trigger is activated. You can also receive a snapshot from a connected camera so you can verify the situation immediately. This means you can respond quickly whether you are at work, on holiday, or just in another room. Notifications keep you in control and ensure your system is more than just loud alarms.
Creating different security modes
With Homey’s Advanced Flows you can design a security system that goes far beyond basic alarms. Instead of simple on/off triggers, you can combine multiple conditions, schedules, and device states into a single automation. For example, you can create a “Home” mode where motion sensors only control lights, an “Away” mode where the same sensors trigger sirens and notifications, and a “Vacation” mode that protects your home by simulating presence while you are away.
These modes can switch automatically based on presence detection, geofencing, or time of day. You can even layer triggers, such as sending a notification on the first movement and sounding a full alarm if movement continues. Advanced Flows give you complete flexibility to build a tailored alarm system that matches your lifestyle.
Expanding your system over time
One of the biggest advantages of using Homey for security is how easily you can expand your setup. You might start with just a few motion sensors and a smart bulb, then later add cameras, smart locks, vibration sensors, or dedicated sirens. Because Homey works with more than 50,000 devices from over 1,000 brands, you are never locked into one ecosystem. Your security system can grow step by step, always adapting to your needs and budget.
Getting Started
You don’t need to invest thousands to get started. A basic setup can be as simple as a Homey Pro, two motion sensors, a door or window contact, and a smart bulb. With just these devices, you can already create Flows that detect movement, send notifications, and even deter intruders by flashing lights or playing alarms through your speakers. This entry-level setup gives you a strong foundation to build on while keeping the cost manageable.
From there, you can expand your system step by step. Add cameras for visual verification, smart locks for secure access, vibration sensors for extra protection, or additional lighting for presence simulation. Because Homey works with more than 50,000 devices from over 1,000 brands, you are free to choose the products that fit your home and budget. Whether you keep it simple or grow it into a fully featured smart security system, Homey gives you the flexibility to do it your way.
