Common Heat Pump Mistakes – And How to Prevent Them
A heat pump delivers its highest efficiency when it can run for long, steady periods at a low supply temperature. In practice, however, things often go wrong due to bandwidths (hysteresis) that are too narrow or switching behavior that is too fast. This results in "short cycling," higher energy costs, and a significantly shorter lifespan for your equipment.
Below are the most common mistakes and the concrete solutions to fix them.
1. Bandwidth Around the Setpoint Too Tight
Mistake: The room thermostat or TRV is set so tightly (for example, ±0.2°C) that the heat pump constantly switches on and off to correct even the tiniest deviations.
Result: This leads to many starts per hour, a lower COP due to constant warm-up losses, audible fluctuations in flow, and extra mechanical wear.
Solution: Set a wider bandwidth—for example, ±0.5 to ±0.7°C for underfloor heating and ±0.4 to ±0.6°C for fast radiators. Combine this with a low supply limit and let the control modulate the output rather than simply switching on and off. Where possible, use a weather-dependent heating curve so the heat source can continuously adjust at low output.
2. Switching Too Fast (No Minimum Run/Stop Time)
Mistake: The controller switches off immediately as soon as the setpoint is reached, and then switches back on at the smallest drop in temperature.
Result: This causes short cycling, poor seasonal performance (SPF), audible comfort issues, and a much higher chance of component failure.
Solution: Set minimum run times (e.g., 10–15 minutes) and minimum stop times (e.g., 20 minutes). Some controllers call this "anti-short-cycling" logic. In combination with a small buffer tank or sufficient water content, this stabilizes the heat source significantly.
3. Oversized Heat Pump or Minimum Output Too High
Mistake: The heat pump chosen is too large for the home or does not modulate low enough relative to the actual heat demand.
Result: Even with perfect control settings, the unit continues to short cycle because it produces more heat than the house can absorb, making the system feel "nervous."
Solution: Ideally, choose a device with a low minimum output and sufficient modulation depth. For existing systems, you can lower the supply temperature, increase water content (by adding a buffer tank), and limit simultaneous heat demand per zone. It is always better to run long at low output than short and hot.
4. Heating Curve Too Steep or Too High
Mistake: The weather-compensated control demands supply temperatures that are too high, even when outdoor temperatures are mild.
Result: This leads to unnecessarily high return temperatures, less condensation efficiency (in hybrid setups), a lower COP, and temperature overshoot in your rooms.
Solution: Flatten the slope of the heating curve and lower the parallel shift in small steps. Observe the results for 3–5 days each time. The goal is to find the lowest possible supply temperature that just meets your comfort needs, without requiring extra heating during peak moments.
5. No or Poor Hydraulic Balancing
Mistake: The flow rates per loop or radiator are not balanced, meaning some zones swallow all the flow while others remain lukewarm.
Result: You experience slow warm-up times, unnecessarily high supply temperatures, hissing pipes, and unstable behavior when valves close.
Solution: Adjust underfloor heating loops using the flow meters (starting point 2–3 l/min, with a ΔT around 5–7 K) and balance radiators with preset valves (ΔT often 10–15 K). If many thermostatic valves are present, add a differential pressure valve to maintain flow.
6. Too Aggressive Night Setback and Morning Peak
Mistake: Lowering the setpoint sharply at night (e.g., by −3°C) and then raising it quickly in the morning.
Result: This causes morning spikes with high supply temperatures, long warm-up times, lower comfort at breakfast, and poor efficiency.
Solution: Use small steps (e.g., −0.5 to −1.0°C) and schedule preheating 45–90 minutes before the desired comfort moment, especially with underfloor heating. Keep the supply temperature limited and let the thermal mass load gradually.
7. Letting Everything Request Heat at Once
Mistake: The bathroom, living area, bedrooms, and domestic hot water production all demand power simultaneously.
Result: This creates high electrical peaks, a risk of voltage dips, unnecessary starts, and a lower overall COP.
Solution: Phase your demand. Give the living zone priority, heat the bathroom briefly in between, and handle bedrooms later. Schedule domestic hot water in separate windows (e.g., during low price periods or PV peaks). If your controller supports it, set a limit for the maximum number of simultaneous zones.
8. Awkward Domestic Hot Water Strategy
Mistake: Heating the hot water tank too often, or at unfavorable times to unnecessarily high temperatures.
Result: This results in many starts, a low COP, and wasted energy consumption.
Solution: Heat domestic hot water during cheap hours or when you have a PV surplus. Limit unnecessary reheating throughout the day. Furthermore, schedule the high-temperature legionella boost weekly in a favorable window, rather than doing it daily.
9. Sensors Placed Incorrectly or Poorly Calibrated
Mistake: The room sensor is placed in direct sunlight, near a radiator, or on a cold exterior wall. Similarly, supply/return sensors might be poorly attached.
Result: The controller "sees" a distorted signal and corrects too early or too late, leading to erratic behavior.
Solution: Place the room temperature sensor at a representative height and location, away from heat sources or drafts, and calibrate it if needed. Also, check the mounting and insulation of your supply/return sensors.
10. No Attention to Defrost Behavior
Mistake: An air/water heat pump cycles frequently to defrost during freezing weather, but the system has too little thermal buffer to handle it.
Result: This causes temperature fluctuations in the indoor circuit and forces the unit to restart more often.
Solution: Ensure sufficient water volume or install a small buffer tank, and keep the supply temperature low. Additionally, good placement of the outdoor unit with free airflow shortens the required defrost time.
11. Controlling Based on Price but Ignoring COP
Mistake: Looking only at the dynamic electricity price or PV output without considering the COP and outdoor temperature.
Result: Running at night when it is cheap but very cold can actually be more expensive than running during the day with a slightly higher price but a much better COP.
Solution: Create rules that combine price and a COP proxy:
  • "If outdoor is warmer than X°C or supply is below Y°C → heating allowed."
  • "Otherwise, only run at very low/negative prices and with small setpoint steps."
12. Setpoint Steps Too Large
Mistake: Jumping from 18.5°C to 21.0°C in one go.
Result: This requires a high supply temperature, leading to overshoot and system instability.
Solution: Work in small steps of 0.5–1.0°C and start preheating on time. Let the heat flow gradually into the thermal mass of your home.
With these guidelines, you let the heat pump do what it does best: deliver heat long, calmly, and efficiently, without nervous switching moments or unnecessary costs. By avoiding these common mistakes, you ensure comfort and longevity for your system.
