![Home Automation 101: how it works & where to start](https://blog.athom.com/wp-content/uploads/2019/06/domotica-1024x512.jpg)
![](https://blog.athom.com/wp-content/uploads/2019/10/smart-home-1-2000x775.jpg)
How it works
![](https://blog.athom.com/wp-content/uploads/2019/07/Lights.png)
How to create home automation
![Homey Flow for home automation](https://blog.athom.com/wp-content/uploads/2019/10/homey-flow-mobile.jpg)
Home automation on your phone
Home automation on your PC
![home automation with Homey Flow for Web](https://blog.athom.com/wp-content/uploads/2019/02/2-small.png)
