Introducing the Matter Bridge app for Homey Pro
Discover the Matter Bridge app for Homey Pro. Easily control your devices through other platforms that support Matter, including Apple Home, Google Home, and Alexa.
Bring your platforms together
The best control is often the one that’s already at hand, whether that’s asking Siri to dim the lights or using a quick routine in Google Home. The Matter Bridge app lets you tap into the conveniences of other ecosystems through Matter, such as voice control.
Your devices appear naturally in your other platform’s app, right alongside native ones. You can even expose non-Matter devices that normally wouldn’t be supported elsewhere. For example, your 433 MHz blind or a Z-Wave thermostat can now show up in Apple Home.
Simple to set up
Once you’ve installed the Matter Bridge app, go to More (…) → Settings → Matter Bridge in the Homey Mobile App or Settings → Matter Bridge → Configure in the Homey Web App. Scan the QR code with your Matter controller, select the devices you want to bridge, and you’re done.
Give it a try
The Matter Bridge app is compatible with Homey Pro (Early 2023) and Homey Pro mini. It lets you bridge a wide range of devices, including lights, thermostats, plugs, locks, blinds, sensors, and alarms — all while keeping Homey Pro at the heart of your setup.
